eSI help!
Old Jun 30, 2008 | 06:57 PM
C5nKY's Avatar
C5nKY
Default eSI help!
The search function doesn't yeild the answer I'm looking for.
eSI seems to run but keeps telling me I need to install the stand alone data. I installed the data but eSI insists I haven't.
What is the path to direct the data install? Is it a seperate folder inside the GM SPO folder or where???
I'm trying to get it to run, under administrator, in Vista.
Old Jun 30, 2008 | 08:45 PM
Patches's Avatar
Patches
How many disks did you install total? Did you follow installation instructions to the letter? What version do you have? Did you install an update disk that may have come with your set?
Not sure if it's compatible with Vista as I have only run it on Millenium and XP on both laptops and desktops. I have had installation issues but that was usually related to certain Dell configs.
Old Jun 30, 2008 | 09:30 PM
ljthe2nd's Avatar
ljthe2nd
I've got a Dell Inspiron E1405, I bought a copy of eSI on DVD from a forum ,member. I tried everything I could and couldn't get it to run. I tried suggestions that I found online, I tried help from forum members, nothing would work. I kept getting the same message you are. I finally did and uninstall and purchased a genuine GM copy on 7 CD's and it works fine. By the way I'm running XP home edition.
Old Jul 1, 2008 | 12:22 AM
C5nKY's Avatar
C5nKY
I need to find a set of those CDs.
Old Jul 1, 2008 | 12:27 AM
DeeGee's Avatar
DeeGee
I've never had much luck with that program. I could never get it to run, apparently its due to security settings and firewall issues.
I gave up and ordered the paper manual
To eSI help!
