[Z06] Post Dyno sheet & Mods
Old Jun 30, 2008 | 10:44 PM
karpetcm's Avatar
karpetcm
Default Post Dyno sheet & Mods
Well i see alot of claims of some really crazy dyno numbers with no mods or just one or two things done to Z06's. So lets see some dyno sheets and what mods youve done to your ride. State if youve also put it on the rollers if the car was hot or cold because that does and will in most cases make a difference. This thread is really for me to get an idea of what works and doesnt on the C5Z and with the right mods how much you can get up to. Also state what kind of dyno your Z was on that also plays a big part as well sometimes in the numbers, thanks in advance.
Old Jul 1, 2008 | 08:57 AM
AlwaysInBoost's Avatar
AlwaysInBoost
see sig
Old Jul 1, 2008 | 09:45 AM
vettefamily's Avatar
vettefamily
652 rear wheel horsepower (740 engine HP)
Performance Upgrades Include:
MTI Low Compression 347 with Lunati Rods, ARP Rod Bolts and Wiseco Pistons
ARP Main Studs
Double Roller Timing Chain Set
ARP Head Studs
Ported LS6 Oil Pump
Billet Steel Flywheel
B&B PRT- TriFlo Catback Stainless Steel Exhaust
LG PRO Headers With Off Road X Pipe
Textrailia OZ700 Clutch with New GM Master and Slave Cylinder
AFR 225 Mongoose Cylinder Heads
ATI D1SC Procharger with Procharger Stage 2 bracket
A&A Corvette Front Mount Intercooler Kit
A&A Corvette Custom Fuel System
ECS Alky-Control Methanol lnjection System
Upgraded T56 Transmission
Autometer Cobalt Boost and Fuel Gauages
B&M Ripper Shifter with Handle
Old Jul 1, 2008 | 11:01 AM
karpetcm's Avatar
karpetcm
I might of missed out on something but just dyno sheets posted and the mods with it. Lets keep it friendly for once, thanks in advance.
Old Jul 1, 2008 | 11:47 AM
Toque's Avatar
Toque
From: Wylie TX --> Less is More, except under the hood !
More details on my web page in my signature...
Old Jul 1, 2008 | 11:49 AM
karpetcm's Avatar
karpetcm
^^^Nice, thanks Toque
Old Jul 1, 2008 | 01:12 PM
Slow Z06's Avatar
Slow Z06
Mods on sheet 437 - 402
Diferent dyno 2 weeks later( Mustang shop dyno day ) The 428 he let out at @ 6500 440 was let out at @ 7000
We didnt log the TQ as it was too erratic. It peaked however at 463
I will do another run when I am finished tuning it. A few other tuners looked at my files and believe ther is another 10 rwhp in there after tuning the cruise cells and getting the AF where I want it. The I will make the run with the 250 shot on it.
Old Jul 1, 2008 | 01:57 PM
Savior1974's Avatar
Savior1974
Stock C5Z06 w/ Intake lid removed and dyno tune.
385whp/368wtq-SAE corrected
Done on the Dynomite (Land and Sea) Loaded Dyno @ RPM Motors Inc in Santa Clarita CA by Charlie
Video of My car on the Dyno.
YouTube - Stock 2003 Corvette Z06 Dyno
Old Jul 1, 2008 | 02:16 PM
Higgs Boson's Avatar
Higgs Boson
628/638 rwhp/tq
dry 150 shot on a 408ci, 243 heads (small), 236/244 on 114 (small), AR 1 7/8 headers, stock Ti, RAM Twin Disc clutch, stock trans/rear.
motor is built to take whatever I want to spray so I will try 200 and 250 in my search for 750/800 or so. going to wet shot as well.
It put down 510/480 NA but the timing is backed way down for spray right now.
Old Jul 1, 2008 | 02:45 PM
jpandes's Avatar
jpandes
Default Heads are coming next...
Dyno Jet#'s: 429 rwhp & 392 ft.lbs
  • Cam 228/232 115 lsa
  • AR 1 7/8" LT headers w/ hi-flo cats & x pipe
  • Vararam
  • Stock Ti cat-back
  • Underdrive pulley
  • Tuned by Newtech performance
Old Jul 1, 2008 | 05:44 PM
Spritle's Avatar
Spritle
HP is at the tires on a Dynojet Dyno, engine temp was between 180/190 degrees.
2003 Z06
Forged 346
TFS Heads
A&A Cam
60lb Injectors
KB Boost-A-Pump
Kooks 1-7/8" longtubes (no cats), stock Ti exhaust
Procharger D1SC @ 15lbs w/ 3.9" 8 rib pulley
Snow Methanol injection
LS7 Clutch
Old Jul 1, 2008 | 06:38 PM
Savior1974's Avatar
Savior1974
wow.. my dyno is pathetic compaired to the others.
Old Jul 1, 2008 | 07:43 PM
cdn ws6's Avatar
cdn ws6
The car is not yet in my posession but will be soon
2003 Z06, 18000 miles, factory LS6 through factory exhaust on a dynojet, 547rwhp and 451 rwtq
Mods are,
A&A Procharger P1SC kit with front mount intercooler, Dewitts radiator, Textralia OZ700 clutch, Kenne Bell Boost-a-Pump, Lingenfelter hardened output shaft, Autometer fuel pressure and boost pressure gauges in A-pillar pod, upgraded Vortech blow off valve from A&A, upgraded injectors from Andy, upgraded spark plugs and a lowered thermostat. Tuned for 91 octane by Phil at Skunkwerks.
Old Jul 1, 2008 | 08:48 PM
jpandes's Avatar
jpandes
My thoughts exactly.
Old Jul 1, 2008 | 08:55 PM
karpetcm's Avatar
karpetcm
384 rwhp is a really good number especially with those mods. So i dont think you have much to worry about either way thanks for posting the numbers.
Old Jul 1, 2008 | 10:44 PM
Threed's Avatar
Threed
From: GOCC - Rebels Without A Clue Santa Barbara, CA
w/ 3:90 gears on a Dynojet stock intake, throttle body, and non milled heads.
Old Jul 3, 2008 | 06:00 PM
cdn ws6's Avatar
cdn ws6
Old Jul 8, 2008 | 05:12 AM
David426's Avatar
David426
These posts always amuse me because so many (most) folks are completely cluless on dynos and results.. Comparing results is like comparing oranges to apples.. And yes I too used to be cluless
Remember:
Different dynos ie.. makes/models give different numbers
The same dynos give different numbers. Depending on calibration,smoothing settings.. Dyno Operator makes his own descision on Dyno claibration.
The same dynos with different operators give different numbers
Dyno calibration settings vary and can be changed from SAE to Standard by the operator, giving totally different dyno numbers
Altitude,humidity,temperature can have a huge effect on dyno results when not using SAE corrected settings
/ Speed shops can exaggerate numbers by using certain calibrations to inflate thier numbers ( A happy client will come back if his numbers look good). Sad but true some People lie or exaggerate on this forum
Dyno Jet SAE corrected rwhp on a Stock LS1 A4= 280-290 6spd 300-310
Best thing to do is stick with the same operator and same Manufacturer/model Dyno from Bone stock - all modifications
Don't rely on what others say about THEIR cars output based on the above information I have provided.. I've seen bone stock numbers from 270rwhp to 360rwhp (LS1) depending on the above... Unfortunately no one knows to post all the above information when they post their dyno numbers... Its all a big joke, unless the poster knows the answers to all these questions or knows exactly what the operator of the dyno is using, which is critical when comparing with others... Like I said its like comparing apples and oranges
To Post Dyno sheet & Mods
