Fob Issue
Old Jul 3, 2008 | 08:22 PM
csc67's Avatar
csc67
Default Fob Issue
Below is a picture of my fob that doesn't work - There is a small piece about 5/8 long by 1/4 wide that has D32 7L9 on it. Is the piece supposed to be solder on somewhere and came loose?
I tried changing the battery, but that didn't work
If someone has a picture of the inside of their fob - Sent away
Old Jul 4, 2008 | 12:32 AM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
I'll look later tonight when I get home. I'm at work right now. You are missing a can type item which I will assume is the one you are talking about and if memory serves me correctly, it goes in the bottom left of the picture inside the fob. I'll take a picture of it and send it late tonight.
Old Jul 4, 2008 | 02:58 AM
dgrant3830's Avatar
dgrant3830
This was taken from a FOB for a '99. I was wrong in my previous post as your item goes in your upper left corner. Note the direction of the letter on the part.
Old Jul 4, 2008 | 04:12 AM
WildTurkey's Avatar
WildTurkey
It looks like you might be missing a piece in the upper left. However, mine sometimes stops working and I fix it by holding the lock/unlock buttons simultaneously for 10 secs while aiming it at the drivers door. Good Luck!!
To Fob Issue
