Code P1154
Old Jul 5, 2008 | 01:28 PM
moserbe's Avatar
moserbe
Default Code P1154
Just got this code a little while ago. The car was running fine, no problems. I looked up the code and all that it says is H02S transition time ratio. WTH does that mean. I cleared the code, started the engine and it didn't return....so far. Appreciate any and all help. Thanks.
Old Jul 5, 2008 | 03:25 PM
Optimus_C5's Avatar
Optimus_C5
From: If opportunity doesn't knock, build a door. South West Florida / Livin' The Dream
St. Jude Donor '12
Here's some information on the code. Hope this helps you troubleshoot it.
P1151 OBD Trouble Code
NOTICE: The information contained on this site is presented for information only. OBD-Codes.com is not responsible for any actions you take on any vehicles. If you have any doubt as to repairs on your vehicle, please contact a qualified technician.
Technical DescriptionLack of HO2S-21 Switch, Sensor Indicates Lean
What does that mean? A Heated Exhaust Oxygen (HO2S) sensor indicating lean at the end of a test is trying to correct for an over-rich condition. The test fails when the fuel control system no longer detects switching for a calibrated amount of time.
SymptomsYou will likely not notice any drivability problems.
Causes A code P1151 may mean that one or more of the following has happened:
Electrical:
Short to VPWR in the harness or HO2S
Water in the harness connector
Open/shorted HO2S circuit
Corrosion or poor mating terminals and wiring
Damaged HO2S
Damaged PCM
Fuel System:
Excessive fuel pressure
Leaking/contaminated fuel injectors
Leaking fuel pressure regulator
Low fuel pressure or running out of fuel
Vapor recovery system
Induction System:
Air leaks after the MAF
Vacuum Leaks
PCV system:
Improperly seated engine oil dipstick
EGR System:
Leaking gasket
Stuck EGR valve
Leaking diaphragm or EVR
Base Engine:
Oil overfill
Cam Timing
Cylinder compression
Exhaust leaks before or near the HO2S(s)
Possible Solutions See the above list of causes and go from there.
Old Jul 5, 2008 | 08:37 PM
moserbe's Avatar
moserbe
Thanks Marc, I appreciate your help.
Old Jul 12, 2008 | 01:08 AM
moserbe's Avatar
moserbe
Put it on the laptop tonight and found that one of the rear O2 sensors is locked on 92.2 and not flucuating as the other 3 sensors are. This might be the problem.
To Code P1154
