[Z06] cam for road racing.
Old Jul 6, 2008 | 03:57 PM
rb185afm's Avatar
rb185afm
Default cam for road racing.
I have been searching the endless cam threads. Cant find an answer to this. What is a good grind for road racing. I do a lot of track days. I would love a monster cam like the MS4 but not sure how often I would be replacing valve springs under that kind of abuse. Anyone have any experience with this?
Old Jul 6, 2008 | 03:59 PM
BANDIT HPT's Avatar
BANDIT HPT
Have you looked at a ASA cam?
Old Jul 6, 2008 | 07:42 PM
GeorgeZNJ's Avatar
GeorgeZNJ
St. Jude Donor '08-'09
I've been road racing ECS custom grind, commonly referred to as the GeorgeZ Cam for 3 years now.
Old Jul 6, 2008 | 08:06 PM
Higgs Boson's Avatar
Higgs Boson
under 600 lift and duration around 240/240 on a 108 lsa, imo.
Old Jul 6, 2008 | 08:48 PM
rb185afm's Avatar
rb185afm
Why such a low LSA?
Old Jul 6, 2008 | 09:34 PM
Don O.'s Avatar
Don O.
Default Cam
Been running a MS3 for about two years. It loves Sebring. I even autocross with it!
Don
Old Jul 7, 2008 | 01:47 AM
QUIKSILVERZ's Avatar
QUIKSILVERZ
anthony at LG recommend their g5x1 cam for me. street car that will attend a few open track events a year.
Old Jul 7, 2008 | 11:36 AM
AU N EGL's Avatar
AU N EGL
Originally Posted by rb185afm
Why such a low LSA?
Moves the power and torque band down for more get up and out of corners faster.
Here is a bit of an old thread but it will help
http://ls1tech.com/forums/showthread.php?t=422520
MS4 is a drag racing cam. RR cams may not give you super high numbers, but will have immediate throttle response and get you out of corners ASAP. We all know straight-a-way speed is dependent on your exit speed of your last corner.
Look for charts of cams that will give you more then 300 lb ft of tq at 3000 rpms.
as Higgs mentioned stay under a .600 lift for valve life.
Old Jul 8, 2008 | 02:43 AM
rb185afm's Avatar
rb185afm
Thanks for all the info.
Old Jul 8, 2008 | 09:52 AM
dwjz06's Avatar
dwjz06
Dogface
St. Jude Donor '15, '17
Or their X2 version as well.
Old Jul 12, 2008 | 01:01 AM
Mopar Jimmy's Avatar
Mopar Jimmy
From: Elmhurst, IL (West Suburb of Chicago) & Home of MEGA Horsepower
St. Jude Donor '06
This would be a solid choice among many, many other. Call LGM and talk to LOU he will set you up in the right directoin (being a road racer and having many cams he sells) or better yet call Allan Futral of Futral Motorsports he is a LS cam GENIUS and not arrogant!
Old Jul 12, 2008 | 08:19 AM
Toque's Avatar
Toque
From: Wylie TX --> Less is More, except under the hood !
I agree, call LG's.... Lou bieng a road racer for years will know.
Make sure to get something with a lot of low end torque.... don't focus on top end HP.
As Lou puts it...."HP sells cars, Torque wins races"
Toque
Old Jul 12, 2008 | 10:12 AM
Quick Silver Z's Avatar
Quick Silver Z
St. Jude 15 Year Donor
No-IL Events Coordinator
2025 C6 of the Year Winner - Unmodified
2019 C6 of Year Winner (appearance mods)
2018 C6 of Year Finalist
St. Jude Donor '12 thru '26
I'm sure Lou would give credit to Carroll Shelby for that one.
Old Jul 12, 2008 | 10:48 PM
GeorgeZNJ's Avatar
GeorgeZNJ
Toque
I have 450ftlbs of tq @ 3000 rpms, peaks at 492ftlbs @ 5000, and back to 450 @ 6000 nice flat line.
Old Jul 13, 2008 | 02:08 AM
andrewjhaley's Avatar
andrewjhaley
Woah now,, what is your setup?
Old Jul 13, 2008 | 06:34 PM
GeorgeZNJ's Avatar
GeorgeZNJ
ECS N.A. forged 402.
Old Jul 13, 2008 | 08:50 PM
MattZ28's Avatar
MattZ28
Wrong. It's the exact opposite...higher LSA = lower powerband and vice versa.
To cam for road racing.
Old Jul 14, 2008 | 04:19 PM
rb185afm's Avatar
rb185afm
If this is the case why is the GM ASA roadracing cam on a 110 lsa. Also they have a 108 on the Grand Am Cam. Not saying your wrong just trying to understand why.
Old Jul 14, 2008 | 05:51 PM
SilentFright's Avatar
SilentFright
From: Arlington Texas, originally from San Angelo, TX
Toque
Lou recommended the G5X3 and the G5X4 for LS6 road course duty.
Old Jul 14, 2008 | 09:34 PM
Higgs Boson
duration determines where in the rpm range it makes power and lsa determines how peaky or flat the curve is. lower lsa is a smaller area but a higher peak number and higher lsa is a larger area of power but not as much.
duration and lift combine with lsa to make magic. each criteria by itself is nothing.
i recommended a low lsa because it makes more power and a true road course car has proper gearing and driver shifting to keep the motor in the powerband. if you shift, you don't need power from 2K to 7K.....
