Orange peel
Old Jul 6, 2008 | 10:26 PM
32TUBB's Avatar
32TUBB
1st Gear
Default Orange peel
I need some help. I've got a 1999 corvette convertible. It's all original and has never been in an accident. It's got 37,000 miles on it. The amount of orange peel on the doors amd rear quarters is unacceptable.
Is there enough clear on the paint to allow me to wet sand and buff the the orange peel out of it or do I need to add some clear?
I'd appreciate your input.
Lee
Old Jul 6, 2008 | 10:35 PM
MagRedConv's Avatar
MagRedConv
Hop on over to the Car Care section. Lots of info and a few pro detailers to boot.
Old Jul 6, 2008 | 10:44 PM
slvrzo6's Avatar
slvrzo6
Chances are the Orange Peel or wavys you are seeing is in the Base Coat and the Clear Coat is Magnifying the Orange Peel in the base Coat. I'd take it to a good body shop and see what they think.
Old Jul 6, 2008 | 10:51 PM
dobewillie's Avatar
dobewillie
Old Jul 6, 2008 | 11:29 PM
2KFRC5's Avatar
2KFRC5
I had a small area on the left rear quarter panel that had orange peel, and some light scratches all over (got caught in some winds) from a car cover. I took it to a good (excellent, after-the-fact) detailer. No sanding, only buffing. He did the the entire car an it turned out fantastic. No more orange peel, and the Vette was a mirror.
Good luck with yours. Hoping it'll buff out.
Old Jul 7, 2008 | 01:38 AM
T VETTE's Avatar
T VETTE
Typical cut and polish would require 1500 or 2000 grit sand paper and work up with various compounds to a mirror finish. Depending on how much orange peel.
Have a pro do it, not as easy as it sounds. Could run a few hundred if many panels.
Old Jul 7, 2008 | 07:20 AM
EVIL_C5's Avatar
EVIL_C5
Uber Waxer
Cruise-In 8-9-10-11 Veteran
CI 9, 10 & 11 Car Show Winner
St. Jude Donor '08-'10
I did my entire car, started with meguires unigrit 2500 and moved to 3000 then polished with several passes using wool and foam pads. entire process took me around 80 hours to do but was worth it.
Old Jul 7, 2008 | 08:40 AM
J S Machine's Avatar
J S Machine
St. Jude Donor '10-'11-'12-'13-'14-'15-'16-'17
St. Jude Knife Maker
I'd be very careful cutting (wet sanding) factory clear coat. It is often very thin, and it is easy to burn through. It would definitely fix the "orange peel", but you risk burning through. once you cut it you have to buff it and if you don't know how to use a buffer you can cause more damage than you have already. Not saying you don't know what you are doing by any means, just giving warning a fellow Vetter...
Like another person said earlier-take it to a body shop and let them check it out. They look at this stuff every day, and they can tell you the way to fix it.
Good Luck
PS. Fill out your profile
Old Jul 7, 2008 | 08:46 AM
EVIL_C5's Avatar
EVIL_C5
Uber Waxer
seen body shop work on something like this and often you are better off leaving it the way it is.
a high end body shop is going to charge you by the hour to do it at about 50-70 per.
just things to keep in mind when you are looking around.
when I was looking to get mine done, all I would get is a price per hour or they werent interested in doing it.
Old Jul 7, 2008 | 09:05 AM
RayCE's Avatar
RayCE
Take a look at this post.
http://forums.corvetteforum.com/show....php?t=1810388
Old Jul 7, 2008 | 09:44 AM
Best bet is to talk to a body shop you trust and see if they think it can be easily fixed. Good luck.
Old Jul 7, 2008 | 11:09 AM
Quicksilver Vert 01's Avatar
Quicksilver Vert 01
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16
Leave it alone, you could be asking for trouble.
Old Jul 7, 2008 | 11:47 AM
BOTYNV1's Avatar
BOTYNV1
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16-'17-'18-'19
can get into trouble if you aren't careful.(VERY CAREFUL)
Old Jul 7, 2008 | 12:33 PM
Jacks02's Avatar
Jacks02
From my experience having Vettes back to 1962, orange peel has been a "no extra-cost option" for a long time.
Old Jul 7, 2008 | 12:57 PM
EZEDDIE's Avatar
EZEDDIE
If you need to ask about the clear coat, you probably do not have a skills for this tricky work.
Just kidding. Do like everyone says and leave it to the experts. If they F$ck it up, you have someone to blame. If you do it and screw something up, you'll be kicking yourself.
Old Jul 7, 2008 | 01:20 PM
Millenium Z06's Avatar
Millenium Z06
Moderator
Just an FYI, a body shop has no way of determining how thick your clear is. All you can measure is overall thickness and this can only be done on cars with steel panels as the tool used to check paint thickness does not work on anything else.
The difference between you doing it and them doing it is if they burn thru they MAY have to fix it. Most shops will have you sign a document stating that they are not responsible if they burn thru or sand thru since they did not originally paint the car and cannot guarantee someone else's work.
Old Jul 7, 2008 | 01:35 PM
EVIL_C5's Avatar
EVIL_C5
Uber Waxer
they make a paint thickness gauge for fiberglass and plastic, its just VERY expensive.
the clear is thicker than you think and 3000 grit paper will not remove as much clear as a wool pad and compound would in the hands of most body shops.
To Orange peel
Old Jul 7, 2008 | 01:45 PM
doje's Avatar
doje
St. Jude 15 Year Donor
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18-'19-'20
I'm no expert, but it seems that if you polished the car then had a paint shop shoot a couple more layers of clear with polishing between coats, you could then start with a nice thick clear coat. You would then have much less to worry about.
Again, I know nothing about painting cars, so you would want to run this idea by someone who knows better than me.
Old Jul 7, 2008 | 02:24 PM
EVIL_C5's Avatar
EVIL_C5
Uber Waxer
have to scuff the finish with 600 grit, tape everything off, might as well repaint at that point....Thought of this myself and that was the answer I got.
plus to do it right with no tape lines, you would pretty much have to take the car apart.
Old Jul 7, 2008 | 02:28 PM
MyVetteDream's Avatar
MyVetteDream
From: HOW FAST WAS I GOING OFFICER? Los Angeles Hating GM Dealership Service Dept.'s Since Sept. 2004
St. Jude Donor '04-'05-'06-'07
I looked into it a few years ago... that's the same thing the paint guy told me so I left it alone.
