automatic headlamps
Old Jul 8, 2008 | 07:14 AM
corvettejaune's Avatar
corvettejaune
Default automatic headlamps
I have a 2000 with automatic headlamps which is the law in Canada. In low light situations the lights pop up. I have heard that there is a fix for this to allow the driver to control when the lights go on
help please regard Michel from Montreal
Old Jul 8, 2008 | 08:15 AM
pointu's Avatar
pointu
From: sometimes the lights are shining on me, other times i can barely see minnesota
you can turn it off in options-i believe its called twilight sentinal or something like that.
Old Jul 8, 2008 | 08:17 AM
Patman's Avatar
Patman
I don't believe the Canadian cars have the option of turning it off via the options menu, only the US cars can do this.
Old Jul 8, 2008 | 11:54 AM
c5streak's Avatar
c5streak
Not an option on Canadian RPOd cars.
I think there are two ways which may work on the Canadian cars, not 100% sure on either one.
1)Pull up the emerg brake 1 click. (I think you also lose your DRLs and your brake light in the IP may light up.)
2)Pull micro relay #44 in the pass footwell. (you may lose your DRLs here also.)
Both are free and worth a try. Let us know if either solution works.
Old Jul 8, 2008 | 12:31 PM
rbrtclk's Avatar
rbrtclk
If you pull micro fuse #44 (under passengers footwell) It will not effect anything else, but it will let you use the light switch in a normal fashion. The twilight sentinel feature will be disabled.
To automatic headlamps
