I just found a small coolant leak from the water pump of my 02Z. It doesn't look like its any of the hoses but I can't really tell. I am driving from Phoenix to South Texas (1k+miles)this weekend and I won't be able to take it to a shop untill I get to Texas. Has anyone had this problem? I'd appreciate any advice. Thanks.
I had same problem on mine ...it was leaking lower from the water pump..so what i did I took the pump off ...had to remove few things jut to get to the pump ..............cleaned .....Used the that red silicone i think it called Hi temp RV silicone or gasket maker...and put it back on ...and never had the problem since.....just my 5 cents ......good luck
Bob,
