Clearing DIC after running codes.
Old Jul 8, 2008 | 09:04 PM
Choreo's Avatar
Choreo
Default Clearing DIC after running codes.
Is there a way to clear the readout after running the codes? I seem to always have to wait for the readout to clear on its own before I can access other information?
Old Jul 8, 2008 | 09:06 PM
MR.WaynesWorld's Avatar
MR.WaynesWorld
From: The real question is; When you turn your car on, does it return the favor..
Cruise-In VIII & IX Veteran
St. Jude Donor '07-'08
If I remember correctly you just hit reset. I may be wrong. I have had to do it a couple of times but can't remember how I did it...
Old Jul 8, 2008 | 09:10 PM
Quick Silver Z's Avatar
Quick Silver Z
St. Jude 15 Year Donor
No-IL Events Coordinator
2025 C6 of the Year Winner - Unmodified
2019 C6 of Year Winner (appearance mods)
2018 C6 of Year Finalist
St. Jude Donor '12 thru '26
1. Turn the key to the ON position, but don't start the engine.
2. Clear any messages displayed on the DIC by pressing the RESET button.
3. Hold the OPTIONS button down and press the FUEL button 4 times. The computer will automatically display all the codes it has created. It will cycle through each code every 3 seconds.
Note any code that ends in H is a history code indicating something that has occured in the past but is fine now.
Once the computer has finished going through all of the codes, press RESET to enter the manual configuration mode. It will start with a module and show "NO CODES" or '#CODES".
To clear the errors, once in manual mode, press and hold RESET until it displays "NO CODES". Press OPTIONS to go the next module. Repeat this step until you reset the codes in all the computer modules. Only reset the codes if you want to. It is not nessary to do this.
Old Jul 8, 2008 | 11:54 PM
Choreo's Avatar
Choreo
Pressing RESET does nothing on my car after the code sequence has reached the end of its run. Tried pressing RESET several times as well as holding it in, but it still dominates the display for at least a minute after it parks on the last screen?
Old Jul 8, 2008 | 11:57 PM
Choreo's Avatar
Choreo
Yes, everything works exactly as your procedure states, but when it reaches the end of the code sequence I cannot say check tire pressures, etc. for at least one minute because I cannot dismiss the last code screen manually - just have to wait it out?
Old Jul 9, 2008 | 12:45 AM
GrayC5's Avatar
GrayC5
Press the E/M button to exit the diagnostics mode at any time.
Old Jul 9, 2008 | 12:52 AM
DeeGee's Avatar
DeeGee
Or turn off the ignition.
Old Jul 9, 2008 | 01:04 AM
Choreo's Avatar
Choreo
That did the trick! I knew there was a way - just forgot!
Old Jul 9, 2008 | 10:18 AM
bucwheat's Avatar
bucwheat
I have a check engine light come up ,a friend of mine who is a BMW tech hooked up to a ODB and pull codes,the only thing that came up was the right bank was running rich and it could be the manafold drawing a little air.He cleared it and the next day it came back.I have a fuel pressure reg on this car and adjusted it to specs.Any Ideas?
To Clearing DIC after running codes.
