Door hinge lubricant...?
Old Jul 13, 2008 | 03:08 PM
der451b's Avatar
der451b
I am try to be smart , lubricated W40 to plastic hinge ( center console).
Guest what! next day all hinges were falling apart
That is my
Old Jul 13, 2008 | 04:46 PM
10U 99's Avatar
10U 99
St. Jude Donor '08-'09
Originally Posted by merlin5353
Uh, how do they milk the mice?
very carefully
Old Jul 13, 2008 | 05:16 PM
69's Avatar
69
Cruise-In VI Veteran
Being in the Aerospace Biz, I use ACF-50
http://www.learchem.com/Aviation.htm
Old Jul 13, 2008 | 07:57 PM
C5C6Norm's Avatar
C5C6Norm
From: Lower, Slower Delaware, formerly from Mobtown, MD (Baltimore)
Anybody remember 3 In 1 oil? It works.
Norm
Old Jul 13, 2008 | 10:38 PM
waunavet's Avatar
waunavet
St. Jude Donor '20
Originally Posted by Black Out
Lithium aerosol is your best bet....
The biggest misconception is that WD-40 is not a lubricant or a way to grease up mechanical parts... it's actually a degreaser, rust prohibitor, and helps break down dirt, oil, or grease for cleanup.
WD40 is actually a Water Displacement (WD) product.
Old Jul 13, 2008 | 11:06 PM
Originally Posted by 10U 99
white lithium aerosol with a straw for precise application
It works just fine.
Old Jul 14, 2008 | 08:25 AM
nj02vette's Avatar
nj02vette
From: Marlton. Increasing performance one speeding ticket at a time! NJ
Originally Posted by borkg2006
WD40 was created in 1953 as a rust preventative solvent and de-greaser to protect early missle parts. The WD stands for "Water Displacement" and the 40 stands for the 40th formula that was successful.
The basic ingredient in it is, believe it or not, FISH OIL!
Completely correct. WD-40 is one of those miracle fluids, but it's not for lubrication.
Surprisingly, it also works great as a fish attractant. Spray your bait with a little WD-40 and the fish hit it like you wouldn't believe.
Old Jul 14, 2008 | 01:12 PM
bucwheat's Avatar
bucwheat
Originally Posted by MyVetteDream
I wouldn't use WD-40 --- it attracts dust and dirt...
I would use some grease instead.
WD is a not a lubricant.
Old Jul 14, 2008 | 01:23 PM
Black Out's Avatar
Black Out
What if you spray it on your car? Will it attract sea gulls with the fish oil scent?
Old Jul 14, 2008 | 01:24 PM
jovette's Avatar
jovette
With very tiny hands and little bitty fingers
Old Mar 23, 2014 | 09:38 PM
JR-01's Avatar
JR-01
Actually WD40 is a lubricant. It just has different applications.
http://wd40.com/about-us/myths-legends-fun-facts/
Myth: WD-40 Multi-Use Product is not really a lubricant.
Fact:
While the “W-D” in WD-40 stands for Water Displacement, WD-40 Multi-Use Product is a unique, special blend of lubricants. The product’s formulation also contains anti-corrosion agents and ingredients for penetration, water displacement and soil removal.
Old Mar 23, 2014 | 10:11 PM
bjones7131's Avatar
bjones7131
Another good use of wd 40 is, if your lawn mower is hard to start after an extended winter, remove plug and spray a little in cylinder, replace plug and it should start right up or remove breather and spray into carb, works really well. Use the lithium on hinges.
Old Mar 24, 2014 | 09:18 AM
  #33
John Madeja's Avatar
John Madeja
Thumbs up for the white grease! use it for my motorcycle have yet to use it on my car stuff is awesome!
