Help Me Decide!!! Hotrod Vs Vette
1968 SS Chevelle Vin 138
Just short of a Total frame-off completed back in 2007. Approximately 150 miles since completed. Always garaged and covered. NEVER driven in the rain!
Vin tag
O6c 456070 110442
St 68-13837 BF 12955 Body
TR 794 NN paint
Vin number
1 3837 82162706
Body:
The following panels were replaced with new GM sheetmetal:
Right rear quarter panel
Right front fender
New SS hood
New trunk pan welded in
Painted 1970 cranberry red
Fully rubberized undercoated
Chassi:
New a-arm bushings
New Brakes with new wheel cylinders, master cylinder
New upper/lower ball joints
New front sway bar bushings and end links
New 4 row radiator made to keep big blocks cool
Engine/Drivetrain:
Non original motor
1967 396 with an energizer cam with .540/.540
.196 heads with stainless 3 angle valves, springs match the cam
Edelbrock high rise intake with a remanufactured Holley 750
Quadra jet
1968 Bourg Warner 4 speed transmission
Hurst shifter
Original 12 bolt rear
Wheels are 15x8 ralley wheels with small center caps, BF Goodrich radial T/A 245/60-15
Disc breaks with booster
New Flow master exhaust super 40 series
Power steering
Interior:
Came original with standard white interior, and was restored to white
New front bucket and rear seat covers, these are original 1969
Deluxe Bucket seats, # 9828390 AV-P5520 Very comfortable!
New sound deadener
New carpet
New gauge set
New dash pad
Inversion tach in dash were clock was
This is a beautiful car that will get you looks, and compliments everywhere you go. You can't go wrong with a car with the classic lines like these Chevelles. It drives smooth, handles great and sounds fantastic. Anyone would enjoy driving this car. Great power to play with and is smooth cruising down the road.
Don't waste time, lest someone running in and getting it before you. Your Z looks great, keep that pretty beast too...
Steve
I came from a '66 Chevelle and have had an El Camino in the past that I would drive on the street and 1/4 drag race and let's say the Vette is far superior in all respects
And I loved my '66 Chevelle too!
Thanks,Matt
Steve
M6 00 Coupe...
While the Mustang gets more attention everywhere I go, the vette is much more fun to drive.....no comparison..
From a financial point of view, the C5 will continue to depreciate, while the Chevelle will become more valuable...But, the bottom line is which will you have more fun with? If I had to sell one of my cars, I'd let go of the Mustang first... try to keep both if you can, you won't regret it...
Good luck with your decision
1 way of looking at it>>>>
Here you go , drive home tonight and see how many Chevelle's you pass on the way....Then see how many vette's you pass!
2nd way of looking at it
Drive the Chevelle 80 miles an hour on the highway and then drive the Vette that speed.... Do like the handling of the vette more or do you want the ole speed ride, no air, etc.... YOUR CALL!!!!
Keep the Vette...........
