Differential fluid change...Additive??
Old Jul 14, 2008 | 08:54 PM
Bills03Coupe's Avatar
Bills03Coupe
Default Differential fluid change...Additive??
I've read so many different opinions on changing the differential fluid, I'm not sure which is best. I've got the Redline 75W-90 gear oil with the additive already in the bottle. Should I add the GM additive or not?
What are you using, and what have been the results?
Old Jul 14, 2008 | 09:03 PM
jrprich's Avatar
jrprich
As you said, the Additive is already in the bottle
Old Jul 14, 2008 | 09:11 PM
Bills03Coupe
True,but I've read that many of you still use the additional additive, while others do not. I've got a bit of noise on tight turns, and want to get rid of it.
Old Jul 14, 2008 | 09:20 PM
Patches's Avatar
Patches
I have Redline in my coupe and Amsoil in the wife's coupe and didn't have to add additional additive to either. That said, you may need to add some to quiet down your diff after filling the diff with one of these although it's not usually required. You'll want to just add a little bit at a time and then drive the car to see if this cures it as you can add too much additive. You should not need to add the whole bottle of additive.
Old Jul 14, 2008 | 11:11 PM
Quicksilver Vert 01's Avatar
Quicksilver Vert 01
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16
I'm also using Redline 75W-90, and didn't need to use any additional limited slip additive with it.
Old Jul 15, 2008 | 01:08 AM
Last C5's Avatar
Last C5
In both my vert and my Z.
Old Jul 15, 2008 | 02:09 AM
Z06ster's Avatar
Z06ster
I just had my entire differential taken out,
http://forums.corvetteforum.com/show....php?t=2077727
When it was put back, I used Mobile-1 75W 90 LS (the LS designation means the limited slip additive is already there). I did not add any additional additive.
Old Jul 15, 2008 | 09:46 AM
Bills03Coupe
Did you drive any special way after changing the fluid? Slow Figure 8's in a parking lot is a recommended practice, from what I've read.
Old Jul 15, 2008 | 11:14 AM
Bohannin's Avatar
Bohannin
Same here... I did do a few forward and reverse figure 8's in a parking lot, and haven't had any noise at all.
Old Jul 15, 2008 | 02:08 PM
scottydog's Avatar
scottydog
Only use the additive as needed. Too much and the diff will slip too much.
I run stock Redline no problem.
Old Jul 15, 2008 | 06:24 PM
Quicksilver Vert 01
I did 8 or 10 slow fiqure 8's to work the new fluid into the clutch packs.
They also say no W.O.T. for the next 500 miles, but that takes alot of self control to do!
Old Jul 21, 2008 | 10:49 PM
Bills03Coupe
Default Differential fluid change update
After 140 miles, it's like a brand new car! The groaning and creaking on tight turns is completely gone. I used the Redline 75w-90 without adding additional additive. No special driving after the change, just got in and drove it! The whole process took 20 minutes. I find it hard to believe dealers charge $140 for this service, it's that easy!
Old Jul 21, 2008 | 11:19 PM
Cobra4B's Avatar
Cobra4B
CI 3-5-6-7-8 Veteran
I run Amsoil in mine... I dont add any GM additive, no issues. After swapping I go do a few figure 8s to get it all worked in. If you do hear any chatter its easy to pull the fill plug and squirt a little additive in.
To Differential fluid change...Additive??
