turn signal
Old Jul 17, 2008 | 04:40 PM
redroket's Avatar
redroket
Default turn signal
I have looked in the book but cannot find how you change the bulb in the front turn signal on my 02Z? Anyone done this before?
Thanks for any help.
Old Jul 17, 2008 | 04:49 PM
BWF07's Avatar
BWF07
St. Jude Donor '11
Oldtimer
I have done it. Turn on your headlights so they popup. Next remove the bezel around the headlight. Once you have that removed, you can reach down through that area to the socket. Simply twist teh turn signal socket to remove it from the housing. If you cannot get your arm in that way, I understand that you can do it from under the car, but it is more involved.
Old Jul 17, 2008 | 04:53 PM
poolboy's Avatar
poolboy
there's an access panel just ahead of the front tire - a few screws and you can get right at it. Others has said they move the duct for the front brake and reach in that way
Old Jul 17, 2008 | 05:23 PM
10U 99's Avatar
10U 99
St. Jude Donor '08-'09
regardless how you access the socket you should be familiar with how the socket fastens and latches to the turn signal housing. if you've never changed a bulb before it helps to know how it works before you get your hand up there. remove one of the rear tail lights and check it out.
Old Jul 17, 2008 | 05:39 PM
redroket's Avatar
redroket
Default turn signal
Thank you all for your comments and help! I will change it tonite!
Old Jul 17, 2008 | 10:04 PM
DeeGee's Avatar
DeeGee
you'll get three suggestions
Go in through the brake ducts - not easy with a Z06 or if you have screens
Go in through the bottom by taking out the bottom panel
The one that works for me is:
Turn on the headlights and back off one position to kill the lights.
Unscrew the 3 small screws on the black plastic housing around the headlight. Gently pull the housing clear. Reach down around the headlight unit and release the bulb holder. It unscrews counter clockwise but it has a plastic clip which you need to squeeze to release it. Change the bulb. Reseat the bulb holder and turn until it clicks back in place. Put the plastic housing back in place making sure to locate the small plastic tab in the bracket on the headlamp cover. Replace the 3 screws and close the lights.
10 minute job. Some guys have had the lights close if they’ve taken a while to do the fix. If you’re worried about that, disconnect the battery once the lights are up.
The bulb is a 4157NA
Some guys with big arms remove the hood adjusting screw for better access. Guys with even bigger arms have had to take off the headlight cover. Four torx screws (2 back, 1 each side). Take the back ones off first with the lamps down. Raise the lights and take the side ones out.
Old Jul 18, 2008 | 11:19 AM
redroket's Avatar
redroket
Default turn signal
Well I tried last night but could not get the job done! This last post may help me out.
It is a total pain to get this thing up in the air so I may go to a dealer and have it done. I have got to get a set of good ramps!
Old Jul 18, 2008 | 12:08 PM
Benpup's Avatar
Benpup
Cruise-In VI Veteran
Replaced the bulbs, then replaced the bumper lights with the clear ones. Easier from underneath. Don't loose that strange little washer that goes around the socket or you'll get moisture in the lens.
Old Jul 18, 2008 | 03:17 PM
Old Jul 18, 2008 | 04:34 PM
bucwheat's Avatar
bucwheat
Its fun bubba.
To turn signal
