engine shuts off
Old Jul 20, 2008 | 12:52 PM
eglise0's Avatar
eglise0
5th Gear
Default engine shuts off
thanks for the good feed back i ordered the bypass for column lock situation but as i read further someone mentioned the steering wheel actually locking up, mine does not do that you can still steer the car it just quits at 2 miles an hour, is the lock out bypass still the answer.
Old Jul 20, 2008 | 01:20 PM
10U 99's Avatar
10U 99
St. Jude Donor '08-'09
can you turn the steering wheel with the ignition switch in the OFF position?
Old Jul 20, 2008 | 01:31 PM
eglise0's Avatar
eglise0
5th Gear
the wheel is not locked at any time
Old Jul 20, 2008 | 02:38 PM
10U 99's Avatar
10U 99
sounds like the car has had the recall done. from what I understand the original harnesses have to be in place to install the clb.
anyone?
I'm not 100% on this
Old Jul 20, 2008 | 04:06 PM
eglise0's Avatar
eglise0
5th Gear
thanks
lets say the recall has been done do i need to take to dealer to have them fix and if so what do they do and does it last, i just tryed pulling fuses 23 and 25 no change.
Old Jul 20, 2008 | 05:21 PM
Jet-Jock's Avatar
Jet-Jock
Those fuses and clear the codes.
What is the state of your battery? Ensure it is good and not getting weak on you.
To engine shuts off
