man, HORRIBLE luck
Old Jul 20, 2008 | 03:25 PM
glennxx1's Avatar
glennxx1
Default man, HORRIBLE luck
ok, i had a gas leak, it ended up being the fuel filter. Easy enough.
ive never had any break fluid leak at all, i left the car jacked up in the rear overnight. When i came back the next night, i noticed some brake fluid dripping off my exhaust pipe (like it was running down a manifold or something).
wasnt much, so i just hoped maybe some spilled when i checked it that night.
changed my oil and drove my car about 12 miles and parked it, poped the hood, breaks just didnt feel right, was going to check the resevoir.
a small cloud of smoke bellows out, drove it back home, pumped the brakes, fluid came out (about 5-6 good drips for 4 pumps). i wiped up the floor, went back in and pumped the clutch, nothing.
So im pretty sure its a brake line...some where, any ideas where it may be coming from if its dripping off the exhaust in the front near the manifolds?
maybe ill be lucky and it wont be any lines, just the master cylinder
Old Jul 20, 2008 | 03:50 PM
happa's Avatar
happa
is your brake resovior over full? It will leak out the top if it is. I hope you have better luck, good luck!
Old Jul 20, 2008 | 04:45 PM
glennxx1's Avatar
glennxx1
not full, between minimum and max
i dont think its coming from the master cylinder. I felt all around and coudlnt find anything wet around it, i got underneath and felt around, and where the loom is bolted to the body (about a foot? in front of the oil filter) there was fluid dripping off those lines.
still havnt found the actual spot its leaking though
Old Jul 25, 2008 | 07:39 AM
glennxx1's Avatar
glennxx1
so i took it to the dealership, and they said my retaining clip for my clutch line wore through my brake line, they tried to weld/epoxy it, and it still leaked.
They said they had one more thing they'd try before the "only other option", which is "dropping the transmission and putting a new line in"
could i not just put a new braded stainless line instead of a solid steel line? i imagine that would be by far the cheapest option if its a possible swap
Old Jul 25, 2008 | 09:11 AM
sneakelman's Avatar
sneakelman
St. Jude Donor '08-'09
Actually, there are a couple options you have.
1. New hard line.
2. New braided line, not advisable as there is too much movement and it will eventually wear through.
3. Cut (probably best option) out bad section, replace with hard line. Easy enough to flare in a splice in your hard line.
I would NOT allow the dealer to try to EPOXY/WELD my brake line! I can't believe they are even thinking that idea would work. Apparently some moron there doesn't realize how much pressure goes through those lines when you hit the brakes. There isn't an epoxy made I would trust in that application.
I personally would fill the resevoir up, drive it home carefully, jack it up, and replace the bad section with a flared in splice.
JM $.02
Old Jul 25, 2008 | 09:23 AM
CCA Corvette Parts's Avatar
CCA Corvette Parts
Premium Supporting Vendor
St. Jude Donor '07-'08,-'13-'14, '16-'17
Pick up your car and never go back
Peace
Chip
__________________
..................Click for
Old Jul 25, 2008 | 09:53 AM
leadfoot4's Avatar
leadfoot4
Active Streak: 90 Days
Originally Posted by Willfulone
Pick up your car and never go back.....
Man, YOU GOT THAT RIGHT!!!
Epoxy a brake line...ARE YOU F'IN KIDDING????
Old Jul 25, 2008 | 09:59 AM
Mr.Bill's Avatar
Mr.Bill
From: Reno is so close to Hell you can see Sparks , State Of Confusion
St. Jude Donor '12-'13-'14
Wow, The dealer wanted to epoxy a brake line, That is some back yard stuff for sure. Do the right thing, Run Forest, Run.
Old Jul 25, 2008 | 10:17 AM
floridarob's Avatar
floridarob
By far the best option ...
Think I paid 25 bucks for a K&N flare tool that is adequate for the occasional use.
Old Jul 25, 2008 | 11:28 AM
Vector's Avatar
Vector
Originally Posted by Bill K
Run Forest, Run.
To man, HORRIBLE luck
