Cold storage?
Old Jul 21, 2008 | 02:17 PM
TurboTravis's Avatar
TurboTravis
Default Cold storage?
Guys,
There is a good chance that I may have to store my Corvette in a unheated garage all winter. Any negative side effects of this or any special precautions I should take because of the cold?
Travis
Old Jul 21, 2008 | 02:29 PM
10U 99's Avatar
10U 99
St. Jude Donor '08-'09
are we talking about a garage in Houston, TX or Fargo, ND?
Old Jul 21, 2008 | 02:31 PM
TurboTravis
Upstate NY-very cold winters.
Old Jul 21, 2008 | 02:35 PM
Alaskanpilot's Avatar
Alaskanpilot
St. Jude Donor '08-'09-'10
How cold are we talking about?
THere's a few things that you should / need to do:
1. Make sure your washer fluid is of the anti-freeze variety. Standard washer fluid will freeze and can burst things.
2. Keep a full tank of gas in the car, which reduces condensation. This is a good idea regardless of temperature, if you're going to keep the car stored. Maybe put some fuel stabilizer in there too.
3. If you live where it's stupidly cold, you might want to look into a fuel anti-freeze.
4. Check your coolant level and quality.
5. If you have a tire inflator kit, check the temperature on the goopy sealant stuff. I don't know if it can freeze or ruin below a certain temperature. I remember it being pretty versatile, but again I don't know how cold your locale is.
6. You'll probably need some kind of battery tender or trickle charger or something along those lines. I don't know much about these things, but I need to find out more myself, because this winter is the first time I'll have to store mine.
That's all I can think of...
Old Jul 21, 2008 | 02:41 PM
ChipN's Avatar
ChipN
In addition to the things mentioned by Alaskanpilot I inflate my tires to 45 psi, change the oil, and make sure that I have one of those dehumidifying desiccant things inside my car (I use "Rem Dri" for gun safes - costs $10.99 and can be found at most sporting goods stores). My car sits all winters (for the past three winters) and starts right up in the Spring.
Chip
Old Jul 21, 2008 | 02:43 PM
Some Sta-Bil in the gas, Battery Tender on the battery, cover for the car for any dust, maybe some moisture absorbent packets for the inside of the car.
Old Jul 21, 2008 | 02:48 PM
Alaskan Bearbait's Avatar
Alaskan Bearbait
Default Cold start
I also store my Z in the winter. Was wondering what is the best way to build up oil pressure at the first start in the spring. Does anyone have suggestions?
Old Jul 21, 2008 | 05:21 PM
JC in XTC5's Avatar
JC in XTC5
I do an oil change before winter, inflate the tires to about 34 psi since as temps drop the pressure will drop with it, and most importantly I hook up my battery tender.
In my case I don't let it sit all winter and will take it out about once every few weeks when the roads are clean and dry.
Old Jul 21, 2008 | 06:07 PM
Riley P's Avatar
Riley P
As I just bought my car this summer, I believe I will do as suggested here. Change the oil, Sta-bil, ctek (regardless of temp, use it whenever it sits), new rad fluid (I don't know when it was changed last), bleed the brakes (again I don't know when/if this was ever done), and something to remove the humidity from the inside of the car (mostly needed when the air temperature is cycling above and below freezing such as fall and spring), and a sock full of silica gel to take the moisture out of the air in the garage (it's a crappy old garage). I would drive it every couple weeks to get let the oil move, but I don't think vettes mix with deep snow very well.
japc5's Avatar
japc5
I live in Syracuse and store mine in a large building "unheated" with a bunch of other cars.
In addition to what is post 4
Pull the battery and take it home as it could freeze and cause other problems. Trickle charge it throughout the winter.
I put a couple of moth ***** in a plastic bag with a few holes under the seats and in the engine compartment to keep varments aways.
Put a few pounds of extra air in the tires. I go with 5.
If your parking on dirt put plastic under the car to avoid rust.
Put a good coat of polish on the car, and detail the interior.
Place cover on it and say I'll see you in April.
Old Jul 21, 2008 | 06:23 PM
csexton's Avatar
csexton
Works like charm
Chuck
Old Jul 21, 2008 | 06:31 PM
dobewillie's Avatar
dobewillie
all good info amust do is the battery tender!!
Old Jul 21, 2008 | 06:54 PM
John G Pircsuk's Avatar
John G Pircsuk
First of all...heres a link http://www.corvetteactioncenter.com/...e/storage.html that provides information from GM engineers and other "experts" as well. It covers a lot of the controversial issues here on the forum.
I live in Syracuse as well and I'm from the North Country (Potsdam area). My garage isn't heated, but it is insulated. It almost never freezes unless theres a few days of bonechilling cold with some serious wind. I've never had a rodent problem either, probably because my garage is void of "stuff" and not much fun if you're a mouse.
What everyone said about:
1. Full gas tank with STABIL.
2. Check the fluids for proper levels (and mix for coolant).
2. Disconnect the battery and put it on a battery tender. First hand knowledge here that in the winter the batterys will sometimes leak and you know whats directly under your battery.
3. Clean the car (to prevent scratches), then cover it with a good quality cover.
4. I start mine every 2 weeks and let it run for 15 - 20 mins. When I start it i use one of those rechargeable battery packs instead of re-installing the battery every time. Pull up your cover as necessary to prevent contact with anything HOT.
5. Instead of over-inflating the tires I put mine on jack-stands for the winter. I had jacking bridges made and they work great. Just my personal choice for storage.
Good Luck!
Old Jul 22, 2008 | 07:42 AM
fireman591's Avatar
fireman591
No problems in Central MI.
It stays in the garage around 40-50 degrees with a few dips below freezing and a few rises to 60 when I fire up the heater to wash the other cars.
Old Jul 22, 2008 | 08:20 AM
Scriz's Avatar
Scriz
I thought storing with the suspension unsprung was bad. Something about the shocks and springs being used to weight and if they are allowed to hang it isn't good for them. I am curious if there is any validity to that claim as my Vette is stored for long periods of time while I am overseas. I don't have to worry about the cold as it is in Fl., but long term storage is long term no matter where the car is.
Old Jul 22, 2008 | 09:17 AM
firemanbob's Avatar
firemanbob
Putting your car on jackstands is a good idea to relieve the pressure from the tires, but being a fireman....and always thinking....just how fast could you get the vette off those jackstands if your house caught on fire ???
Old Jul 22, 2008 | 09:22 AM
Quicksilver Vert 01's Avatar
Quicksilver Vert 01
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16
Hold the accelerator pedal to the floor, while cranking the engine for about 10 seconds. Oil pressure will build up, but the engine won't start.
To Cold storage?
Old Jul 22, 2008 | 09:29 AM
moserbe's Avatar
moserbe
When I used to cold store my C5 I found that when the battery runs down it doesn't take much for it to freeze. I found out the hard way but luckily it didn't leak, just cost me a new battery.
Old Jul 22, 2008 | 12:30 PM
csc67's Avatar
csc67
Default Storage
Travis,
We are only in July - You have another 4 months of driving
I'm also in NY and store my car in my non insulated garage
Here's what I do:
1) Run AC for 4 minutes
2) Wash car and vacuum interior
3) Oil change
4) Fill gas tank and add stabilizer (be sure to run car for 30 seconds after putting in fuel stabilizer)
5) Inflate tires about 5 PSI
6) Remove targa and roll down windows slightly (helps wear & tear on weatherstripping)
7) Condition seats and weather stripping
8) Put carpet under tires
9) Put trickle charger on
10) Put car cover on
11) Place plastic under car (I do this even on cement floors)
12) Buy three bars of Irish Spring and cut into quarters and place around outside of car to keep mice away
13) Good night kiss and see you on April 1st
14) Remove collision insurance
Like someone else said - Each person has thier own method
Old Jul 22, 2008 | 12:40 PM
Benpup's Avatar
Benpup
Cruise-In VI Veteran
If you have RF's think about parking the car on carpet. You can usually pick up the small rectagles of carpet squares at a carpet store for a buck or two.
Also seal it up as best you can if you have any mice or rats around. They loke nothing better than to spend the winter in a slightly warmer place where they can eat at wiring insullation and seat foam.
