Need code help.
Old Jul 24, 2008 | 05:17 PM
Mr.Bill's Avatar
Mr.Bill
From: Reno is so close to Hell you can see Sparks , State Of Confusion
St. Jude Donor '12-'13-'14
Default Need code help.
I got a code today, It was an H code and I deleted it and all is fine, My question is what the heck is U1160 - Loss of Communications with DDM. What is DDM?
Thanks.
Bill
Old Jul 24, 2008 | 05:39 PM
diyguy's Avatar
diyguy
I think maybe you are missing a letter
More likely LDCM = Left Door Control Module.
Not uncommon - if is shows an "H" and no "C" your fine.
Old Jul 24, 2008 | 05:54 PM
renegad44's Avatar
renegad44
From: This is not a Song, It's an Outburst: Or, The Establishment Blues; Sixto Diaz Rodriguez
Good call....
http://www.stengel.net/diccodes.htm
U1160 Loss of Communications with LDCM
Old Jul 24, 2008 | 06:28 PM
GrayC5's Avatar
GrayC5
Thanks.
Bill
DDM = Driver Door Module. For earlier model year C5s and Diagnostic Trouble Codes (DTCs), it was referred to as the LDCM or left door control module.
DTCs U1001-U1254 are lost communication error messages. The C5 modules are connected via a class 2 serial data circuit. Each module on the class 2 serial data circuit which is powered and performing functions that require a detection of a communications malfunction is required to send a Node Alive message every 2 seconds. When no message is detected from a module in 5 seconds a DTC will be set. The last 3 numbers in the DTC is the ID number of the module that is not communicating. (e.g., U1160H - In this case 160 is the module ID for the DDM.)
HTH
Old Jul 24, 2008 | 06:30 PM
Mr.Bill's Avatar
Mr.Bill
Thanks for the help guys.
Bill
To Need code help.
