listen to the way this starts.
Old 07-24-2008, 07:31 PM
rockgoped
rockgoped's Avatar
Default listen to the way this starts.
hey everyone. need some info. my car is starting wierd. i will turn the key and it wont fire up. then ill turn the key back to off position then attempt to start it again and then it fires up. like its not getting fuel right away or something. im thinking a clogged fuel filter? does this sound correct or not?
Old 07-24-2008, 08:02 PM
BuffaloBillHisself
BuffaloBillHisself's Avatar
Jeesh man, quit worrying about YOUR car and get my side markers done wouldja?
Sure it's not the ignition switch itself Chris? I've read a lot about them being an issue.
hth,
Jim (thebriton)
Old 07-24-2008, 08:09 PM
csexton
csexton's Avatar
Give the resistor pellet on your key a good cleaning and see if that helps
Chuck
Old 07-24-2008, 08:12 PM
rockgoped
rockgoped's Avatar
lol! hey jim. the ignition switch? ill have to check that out!
with the sidemarkers, should be shipped tomorrow, just waiting on my guy to finish up. ill get them asap tho. small world jim.
hth,
Jim (thebriton)
rockgoped
rockgoped's Avatar
Chuck
sounds good. ill try that. thanks
Old 07-24-2008, 09:42 PM
BuffaloBillHisself
We expect a full report Chris.
Jim
Old 07-24-2008, 10:21 PM
dgrant3830
dgrant3830's Avatar
Wounded Warrior Escort '11
If the engine is turning over but not starting, then you need to look at the fuel supply system. If its not turning over at all, is the security light flashing? If so, the pellet in the key needs to be cleaned or the ignition switch replaced. There are further things to check if the security light isn't flashing and the car still isn't turning over, there is a theft deterrent relay that needs to be examined and lots of other possibilities.
Old 07-25-2008, 10:17 PM
rockgoped
rockgoped's Avatar
when the car sits and i go to start the car its delayed. either i will have to crank it longer or stop then crank it again and it will fire up. but if i drive the car and stop. let it sit for 5 min or so then drive again it doesnt hesitate to start most of the time. im going to try some fuel cleaner stuff and see if that helps.
Old 07-25-2008, 11:24 PM
Silverbullet00
Silverbullet00's Avatar
Location: Norman Oklahoma - The Only State in the Union with no Blue Counties!
1. Turn the key to acc and listen for the fuel pump to quit whinning, then start.
2. Run some fuel system cleaner thru her.
3. Make SURE your gas station is not selling 10% Ethanol!
4. Miles on plugs,,,a thousand other ??????'s.
Trying to help!
Old 07-26-2008, 11:50 AM
dgrant3830
dgrant3830's Avatar
It does sound like either a low fuel pressure problem or as you surmised, a possible fuel filter issue which by the way are easy to replace. Have you pulled the codes yet to see what the car is reporting? Yes, could be plugs too... how many miles on the car?
Old 07-26-2008, 01:07 PM
Ilovechevymusclecars
Ilovechevymusclecars's Avatar
[QUOTE=Silverbullet00;1566456983]
QUOTE]
Uh oh....is 10% ethanol bad for our cars?
Old 07-26-2008, 01:45 PM
Mr.Bill
Mr.Bill's Avatar
Location: Reno is so close to Hell you can see Sparks , State Of Confusion
St. Jude Donor '12-'13-'14
[QUOTE=Ilovechevymusclecars;1566461458]
QUOTE]
No, Here in Nevada we been using it for years and have never had any issues, You will find that a lot of states use it already and more will follow.
Old 07-26-2008, 01:50 PM
Ol'55
Support Corvetteforum!
Ol'55's Avatar
Location: Southern New Jersey, The wet part at the bottom
St. Jude Donor '08-'09-'10
Rest assured you have a fuel regulator failed. Your symptom description sounds identical to my fuel regulator problem in an earlier car of mine. New regulator? and all was fine. You could go through the proper pressure testing procedure, but without being there, I'd bet on the fuel regulator.
Post your findings for future searches.
Old 07-26-2008, 02:09 PM
PaintballaXX
PaintballaXX's Avatar
I had the same problem. My ignition was the cause. The contact points were all messed up. With the advice of Bill Curlee. I fixed it to like new condition and the problem was gone. Something for you to consider. http://forums.corvetteforum.com/show...ion+switch+fix
Old 07-26-2008, 06:33 PM
rockgoped
rockgoped's Avatar
thanks guys. all this is helping. the car has 92k miles.
Old 07-26-2008, 07:03 PM
rockgoped
rockgoped's Avatar
http://vids.myspace.com/index.cfm?fu...deoid=39341988
heres some video
Old 07-26-2008, 07:18 PM
YeloFevr
YeloFevr's Avatar
Most people are running E10 and don't even know it.
Old 07-28-2008, 01:27 PM
rockgoped
rockgoped's Avatar
bump
To listen to the way this starts.
Quick Reply: listen to the way this starts.
