Programing tire monitors
Old Jul 25, 2008 | 03:10 PM
GreenDream's Avatar
GreenDream
Default Programing tire monitors
Previous owner put on new tires and the pressures are no longer displayed. Keep getting the "check tire sensors" on display. Dealer is quoting me $76.00 to reprogram. Says it takes an hour. Does this sound about right?
Thanks,
Carl
Old Jul 25, 2008 | 03:13 PM
c5hobo's Avatar
c5hobo
Cruise-In V Veteran
St. Jude Contributor '04
It shouldn't take more than 15 minutes. Look it up in the archives and find yourself a magnet. The procedure is done through the DIC similar to the fob retraining.
Old Jul 25, 2008 | 03:20 PM
GreenDream's Avatar
GreenDream
Thanks. Will do.. I hate dealerships exhorbant rates.
Old Jul 25, 2008 | 03:23 PM
der451b's Avatar
der451b
Take the old used speaker, Hammered on the back to get the Magnet out.
Use that magnet to reprogram tire sensor.
It's free and fun do it yourself on your C5. Save money to buy beer.
Old Jul 25, 2008 | 03:25 PM
02MillenniumVette's Avatar
02MillenniumVette
Here you go.
https://www.corvetteforum.com/techti...D=77&TopicID=1
Old Jul 25, 2008 | 03:35 PM
GreenDream's Avatar
GreenDream
Originally Posted by 02MillenniumVette
Got it..thanks, I will do it tomorrow.. maybe I'll do it in my dealers parking lot..!
Old Jul 25, 2008 | 03:44 PM
OUR97's Avatar
OUR97
"Got it..thanks, I will do it tomorrow.. maybe I'll do it in my dealers parking lot..! "
Old Jul 25, 2008 | 04:00 PM
Robertelarkin's Avatar
Robertelarkin
Default Question
I have to change my right side front and rear wheels. I was going to take the two tires off and take them and the new wheels to a shop I use and have them change out the wheels. After I get this done and put my tires/wheels back on the car................will my sensors have to be reprogrammed?
Old Jul 25, 2008 | 04:35 PM
DeeGee's Avatar
DeeGee
No but make sure they put the tires on the correct side(tires rotate in one direction) and the wheels go back on the corner they came off.
Old Jul 25, 2008 | 04:43 PM
BuffaloBillHisself's Avatar
BuffaloBillHisself
Der451,
THAT is what we're supposed to save money for. NOW I get it.
Tanks Man,
Jim
Old Jul 26, 2008 | 06:06 PM
GreenDream's Avatar
GreenDream
Okay, I did the procedure today. Got the beep at all 4 wheels and still no pressures showing. I did it again, got all 4 beeps. Still no pressures on the console. Does this indicate that the senders may not have been re-installed? Batteries dead? It has the Schraeder valve stems.
Thanks,
Carl
Old Jul 26, 2008 | 06:36 PM
uniqvett's Avatar
uniqvett
My friend had the same thing happen, he was told to drive the car after procedure and it worked fine [ about a 1/4 mile ] good luck
Old Jul 26, 2008 | 06:38 PM
c5streak's Avatar
c5streak
What does the display say for tire pressures? Is it XXX or just blank? Did you drive the car after you programmed them? There is a centrifugal switch in each sensor that requires wheel rotation to activate(min 20 mph). If you go for a drive and they don't start reading , then I would repost this in Tech, as there are some sharp guys over there that don't venture into C5 Gen much.
Old Jul 26, 2008 | 08:51 PM
Corvette Don's Avatar
Corvette Don
^ You need to drive the car over ~10 mph for them to register
Old Jul 26, 2008 | 11:12 PM
If you have a decent magnet, you can program all your sensors in about 5 minutes. It is very easy and no need to have a dealer charge you an hour's labor to do it.
Old Jul 27, 2008 | 07:39 AM
RSchleder's Avatar
RSchleder
Default Spin them!
I agree, take the car out and run it down the road. Spinning the wheels over 10-15mph will allow the sensors to activate!
Old Jul 27, 2008 | 09:52 AM
Bakersfield's Avatar
Bakersfield
You might want to fill out your member profile so we know what year car you drive. If it is a 97 to 2000 year model, your sensor batteries may have died from old age. If the sensors don't read after a short drive, drop me an email about putting in new batteries.
To Programing tire monitors
Old Jul 27, 2008 | 10:02 AM
krzytrain's Avatar
krzytrain
All Aboard!!!
I just had my oil changed and the guys at the dealership did mine for me at no charge.
Makes me feel better for paying 80 dollars for a oil change if i got a $75 service for free.
Old Jul 27, 2008 | 08:39 PM
GreenDream's Avatar
GreenDream
Ahhh.. so your supposed to drive these things.. go figure. That worked. All four pressures are showing now.. Thanks guys..
Old Jul 27, 2008 | 10:36 PM
rws.1's Avatar
rws.1
I just re programmed mine today after installing new snesors...
No exageration less than 3 minutes from start to finish
