Tire Pressure Sensor
Aug 1, 2008 | 01:33 PM
I did a search but did not find the answer.
Do you mount the TPS in the wheel before you put the tire on or tire on the wheel before you install the sensor?
Aug 1, 2008 | 02:14 PM
Sensor in wheel before tire is mounted.
Aug 1, 2008 | 04:07 PM
I put the back side of the tire on first then reach in put the TPS in. That way I cut down 50% of damaging it.
Aug 1, 2008 | 06:07 PM
Thanks for the replys!
I did not want to mess up my new sensors.
Aug 1, 2008 | 06:37 PM
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13
I put new ones in before the tire guy did his thing.......I like a little dielectric on the O ring.........
Aug 1, 2008 | 08:48 PM
Quote:
Originally Posted by
ABNVET.I
Aug 1, 2008 | 09:16 PM
From: Reno is so close to Hell you can see Sparks , State Of Confusion
St. Jude Donor '12-'13-'14
ABNVET.I
You are 100% correct. This is how it should be done.
Bill
Aug 3, 2008 | 09:00 AM
Well guys, every way is covered. My tech put the tire on completely first, then tire changer had arm that pushed sidewall down to get sensor in.... Reason,last time tire rim moved sensor when mounting, o-ring moved out of position, and damaged sensor when tightening to stop air leak... New sensor followed..
