Build Sheet
Old Aug 2, 2008 | 02:23 AM
C598GUY's Avatar
C598GUY
Default Build Sheet
I am a new member to CF, just purchased my first corvette on Fathers Day, and was wondering how to go about getting a build sheet of info on my 98 vette. If anyone can help me out, it would be greatly appreciated. I know that you need a vin #, so here it is 1G1YY22GXW5126100
"The happiest people don't have the best of everything, they just make the best of everything"
Old Aug 2, 2008 | 02:28 AM
jdmvette's Avatar
jdmvette
Night Owl for life
it's in your front bumper rail. you gotta pull your front fascia, though.
Old Aug 2, 2008 | 03:49 AM
DeeGee's Avatar
DeeGee
You might find the one in the bumper is a tad grubby
You can order new copies of your build sheet from NCM
https://store.corvettemuseum.com/ser...buildsheet.asp
I'll treat myself one of these days.
Old Aug 2, 2008 | 05:41 AM
RSchleder's Avatar
RSchleder
Default What are you looking for?
If you're looking for a listing of the options on your car, they can be found on the glove compartment door.
Old Aug 2, 2008 | 07:03 AM
rocco666's Avatar
rocco666
Default Hey guy,
If you send your vin # to the folowing email Mr Gulley will send you a build sheet for your car and along with some other stuff like work history ETC>
Gene Culley (gculley@gmpartshouse.com) for free
Old Aug 2, 2008 | 07:18 AM
kmccon's Avatar
kmccon
First off, congratulations on your new vette. Welcome to the forum and welcome to the family. Remember the WAVE!
On my 98 Coupe, these codes were on the back of one of the side rear storage compartment lids.
Here are the codes for 98:
Decode your own RPO's (1998)
Description
AAB Memory, Driver Convenience Package
AG2 Power Seat Adjuster, Passenger, 6-Way
AK5 Inflatable Restraint System, Front Seat, Driver and Passenger
AQ9 Reclining Seat, Driver and Passenger (Sport Seat)
AR9 Reclining Seat, Driver and Passenger, European Style (Base Seat)
AX4 Conversion, Seat Belt, European
BAG Loose Parts Bag, Export
B34 Covering Front Floor Mats, Carpeted Insert
B4H Modification, Noise Control, Export
B84 Molding, Body Side, Exterior
CC3 Roof Panel, Removable (Transparent)
CF7 Roof Panel, Removable (Nontransparent)
CJ2 HVAC System, Air Conditioning, Automatic Temperature Control (Dual Zone)
CU7 Country Code, Kuwait
CU8 Country Code, Saudi Arabia
CV5 Country Code, Japan
CW2 Country Code, Gulf States
C05 Roof, Convertible Folding
C2L Roof Package, Dual Removable (consists of CC3 and CF7)
C60 HVAC System, Air Conditioning, Manual Control
DL8 Mirrors, Outside, LH/RH Remote Control Electric, Heated
D42 Shade, Rear Compartment Security (includes cargo net)
EXP Export, N.A.E.S.
E45 Cover, Convertible Top, Protective
FE1 Suspension System, Soft Ride
FE3 Suspension System, Sport
FE9 Certification, Federal Emission
F45 Chassis, Selective Real Time Damping
GU2 Axle, Rear, 2.73 Ratio
GU6 Axle, Rear, 3.42 Ratio
G90 Axle, Rear, 3.15 Ratio
G92 Axle, Rear, Performance Ratio
IL3 Trim, Interior Design (L3) (Base w/ AQ9)
IL4 Trim, Interior Design (L4) (Z4Z)
IP3 Trim, Interior Design (P3) (Base w/ AR9)
JL4 Control, Active Brake
JL9 Brake System, Power, Front & Rear Disc, Antilock, 4-Wheel
K05 Heater, Engine Block (Canadian)
K29 Module, Powertrain Control (Non-OBD II, Unleaded)
K63 Generator, 110 Amp
LS1 Engine, Gas, 8-Cylinder, 5.7L, SFI, Aluminum (VIN G)
MAE Marketing Area, Europe
MAU Marketing Area, Unregulated
MM6 Transmission, Manual 6-Speed, Borg Warner
MN6 Merchandised Transmission, Manual 6-Speed Provisions
MX0 Merchandised Transmission, Automatic O/D Provisions
M30 Transmission, Automatic 4-Speed, 4L60-E, Electronic
NF2 Emission System, Federal, Tier 1
NK4 Steering Wheel, Sport Leather
NM8 Leaded Fuel System, Compatible
NN5 Emission Override, California System, Federal
NP7 Steering Column, EEC Approved
N73 Wheel, Custom Sport Magnesium
PA6 Wheel, Styled, Painted
QD4 Wheel, 17.0 x 8.5" Front and 18.0 x 9.5" Rear, Aluminum, Styled
T62 Lighting, Daytime Running -- Delete
T84 Headlamps, RH Rule of Road
T85 Headlamps, LH Rule of Road
T89 Lamps, Tail, Stop & Turn, Export
T90 Lamps, Signaling & Marker, Front
T93 Lamps, Tail, Stop & Turn, Special
T96 Lamps, Fog
UD4 Alarm, Vehicle Speed, 120 km/h
UK1 Radio Frequencies, Japanese
UL0 Radio, AM/FM Stereo, Seek/Scan, Auto Reverse Music Search Cassette, Auto Tone, Clock, Electronically Tuned Receiver (ETR)
UL2 Radio Frequencies, European
UN0 Radio, AM/FM Stereo, Seek/Scan, Compact Disc, Auto Tone, Clock, Electronically Tuned Receiver (ETR)
UV7 Antenna, Windshield, Rear Lift Window, Radio
UZ6 Speaker System, 6, Quad Front Door Mounted, Dual Quarter Mounted
U1S Changer, Remote Compact Disc
U19 Instrument Cluster, Metric (Canadian, Export)
U52 Instument Cluster, Electronic
U75 Antenna, Power, Radio
VB1 Label, Shipping, Japan
VC5 Label, Shipping, Except US/Japan
VD1 Provision Options, Europe
VE1 Provision Options, Japan
VG1 Protector, Transit Coating, Underhood
VG9 Protector, Transit Coating, Exterior Body
VH5 Plate, Vehicle Identification
VL4 License Plate Mounting Package, Front, EEC
V49 License Plate Frame (front)
V73 Vehicle Statement, US/Canada
V76 Tow Hooks
V78 Vehicle Statement Delete
V87 Vehicle Statement, Gulf States
XGG Tire, Front, P245/45ZR17, BW TL SBR HW4, EMT
XMC Tire, Front, P245/45ZR17, BW TL SBR HW4
YGH Tire, Rear, P275/40ZR18, BW TL SBR HW4, EMT
YME Tire, Rear, P275/40ZR18, BW TL SBR HW4
Z4Z Merchandised Pkg, Indy Pace Car
Z49 Modifications, Canadian, Mandatory Base Equipment
Z5X Mirror Provisions, Arabic Language
Z51 Performance Package, Handling
10U Primary Color, Exterior, Arctic White
11U Primary Color, Exterior, Lt. Pewter Metallic
13U Primary Color, Exterior, Sebring Silver Metallic
16T Top Color, Convertible, Bright White
19I Interior Trim, Black
193 Trim Combination, Leather, Black
194 Trim Combination, Leather, Black (Z4Z)
21U Primary Color, Exterior, Pace Car Purple (Z4Z)
23U Primary Color, Exterior, Nassau Blue Metallic
41T Top Color, Convertible, Black
41U Primary Color, Exterior, Black
53U Primary Color, Exterior, Lt Carmine Metallic
58U Primary Color, Exterior, Aztec Gold
67I Interior Trim, Lt Oak
67T Top Color, Convertible, Lt Oak
673 Trim Combination, Leather, Lt Oak
70U Primary Color, Exterior, Torch Red
92I Interior Trim, Lt Gray
923 Trim Combination, Leather, Lt Gray
94I Interior Trim, Firethorn Red
943 Trim Combination, Leather, Firethorn Red
95U Primary Color, Exterior, Md. Purple Pearl Metallic
Old Aug 2, 2008 | 11:12 AM
C5 4 ME's Avatar
C5 4 ME
While you're at it, order the Window sticker also.
Old Aug 2, 2008 | 11:50 AM
merlin5353's Avatar
merlin5353
St. Jude Donor '07-'08-'09-'10
As long as you're at it..........
Old Aug 2, 2008 | 12:52 PM
Cobra4B's Avatar
Cobra4B
CI 3-5-6-7-8 Veteran
I have my original window sticker and I pulled the original build sheet when I put my tighershark nose on. I've been meaning to get them both framed to hang in my garage.
Old Aug 2, 2008 | 01:51 PM
C598GUY's Avatar
C598GUY
Default Thanks
Thanks to each one of you for the wealth of info you have given me. This forum is awesome !!
Old Aug 2, 2008 | 02:38 PM
EPMM 03 C5's Avatar
EPMM 03 C5
got mine right after i bought my vette!!
eric
Old Aug 3, 2008 | 03:27 PM
Turbopower87's Avatar
Turbopower87
Do the letters you found on the storage lid mean the same for all c5s? I am looking at both a 2001 and a 2002 tomorrow and want to be able to decode the options in case the owners don't know all of them... hoping for a hidden z51 upgrade
If not the same, can someone point me to a place with what they stand for on an 01 and 02?
Old Aug 3, 2008 | 07:31 PM
jdmvette's Avatar
jdmvette
Night Owl for life
just look under your hood for a power steering cooler. that will verify if you have a z51.
Old Aug 3, 2008 | 07:32 PM
GrayC5's Avatar
GrayC5
Kudos to Gene and the others here that do this for the Forum members. However, the information they provide is the Build Information from the GM Vehicle Inquiry System (VIS). While GM VIS contains a lot of the same information, it is not the same as the actual Factory Build Sheet and should not be confused with such.
As others mentioned above, copies of your car's Factory Build Sheet can be ordered from the NCM. Following is a pic of a Factory Build Sheet:
To Build Sheet
