Telescopic Steering Probs
Having a prob w/ my telescoping steering wheel SW. won't work going back in and sometimes going out. Have Mem modules 1 & 2 w/ #1 programed for the driver. Sometimes this works, sometimes not. If I move the power seat forward or back then try the memory SW. it might work on occasion.
Also, while driving, the steering wheel might just go back in automatically then I can't bring it back out.
Got numerous codes and they were all History codes except for the following which were History as well as Current.
A6-SCM code B2852 H C Telescoping column In Switch Shorted to Ground
28TCS code C1242 HC Magnasteer Malfunction
I can't clear either of these codes.
Anyone have these problems and just what in heck does it mean by Magnasteer Malfunction?
Any and all help is really appreciated guys!
Resetting the Telescoping Steering Wheel
1) Turn the ignition to the "ON" position but with the engine not running
2) Tap the telescoping button 8 times in the "inward" position then hold the button in the INWARD position for 5 seconds
3) Tap the telescoping button 8 times in the "outward" position then hold the button in the OUTWARD position for 5 seconds
