Installing SS Insert Question
Old Aug 6, 2008 | 08:43 PM
Dark Knight 02's Avatar
Dark Knight 02
Default Installing SS Insert Question
Probably a stupid question....can you use isopropyl rubbing alcohol to clean the indents, the note on the package says use denturated but I'm not sure what that is.....
Old Aug 6, 2008 | 08:58 PM
Shirl's Avatar
Shirl
2025 C8 of the Year Finalist - Modified
2021 C7 of the Year Finalist - Unmodified
Yes, that's fine. I've used regular alcohol (with a q-tip) on Camaro and Corvette rear letter indentations to clean them on 3 different cars.
Old Aug 6, 2008 | 09:16 PM
Dark Knight 02
Thanks!! I figured, but you never know....
Old Aug 6, 2008 | 09:40 PM
10U 99's Avatar
10U 99
St. Jude Donor '08-'09
you're good with regular alcohol.
denatured has been artificially made to be unfit for consumption....... aka nasty
be sure and use adhesive promoter
Old Aug 6, 2008 | 09:59 PM
fireman591's Avatar
fireman591
Ya that is what I used. Heat the letters and car up with a hair dryer and that will help not only dry the alcohol but it will help with the bond by allowing the adhesive to get soft and sticky.
Old Aug 6, 2008 | 10:13 PM
DsC5's Avatar
DsC5
Yup.
Old Aug 6, 2008 | 10:19 PM
I used rubbing alcohol on all of the installs of letter kits on my last car. Never had one problem with the letters staying put.
Old Aug 6, 2008 | 11:42 PM
jrose7004's Avatar
jrose7004
I've always used regular rubbing alcohol on all of my installs and I've never lost a letter.
Old Aug 7, 2008 | 01:29 AM
Dark Knight 02
Default Thanks for every input
I went ahead and installed the letters with everyone's input on using the rubbing alcohol, and I did use the primer too. It was like 85 degree's out so I think I was ok on the heat effect for making it stick.
I'm really liking the touch of bling on my tail....
Thanks again for the input, much appreciated!!
Old Aug 7, 2008 | 01:54 AM
IDM's Avatar
IDM
yup now just make sure it doesnt get wet for about a week
To Installing SS Insert Question
