My tire rant
Michelin has discontinued the entire line of Pilot Sport A/S. It is being replaced with a tire called the Pilot Sport A/S PLUS, and is nearly identicle in design as the old tire, with some improvments, including the irregular wear issue.
I tested these new tires, with some others, for Michelin at there South Carolina proving grounds in June, and they're impressive.
If I recall correctly, the new PLUS tire should be available starting in September.
Thanks for the heads up on this. I know that the new ZR1s come with Michelin tires, so maybe this will be an improvement. I hate my Goodyear runflats, and I'm doing my best to wear them out.
I was planning on getting the Michelins, but I'll make sure I wait for the new " Plus" runflats. BTW, I run my tires at 28 lbs. cold, which brings them up to about 32-34 lbs in the summer heat.
I now have 22,000 on this pair, and I will be seeing cord soon. This is my third pair. After the first pair did this, I ran the second pair down at 25 lbs, didn't help. I have kept this pair at 31 lbs.
My commute takes me across the Mojave dessert and up a mountain road. I do not hot rod it as the place is CHP infested. Usually have the cruise on at 64 mph. I have not been to the track on this pair.
It is an A4 with 2.73s so it doesn't really burn the tires. Tire shop guy says Michelin has been hearing about this and feel it has something to do with centrifugal force on the wide tire pushing the center ourt. Says many cars with the wide tires, Mercedes, etc are having the same issue.
My fronts go over 50K
Anyone have an update on this issue? Anyone found runflats as good as the Michelins that don't do this?
Hope this helps!
Erik
Discount Tire Co.
I'm not seeing the uneven wear on mine after 20k miles but I'll keep a lookout now. I run a little low at about 28 psi cold to get 30 psi hot. I have an A4 with a stock rear end as well.
Now my next problem is how to get a set of the new Michelins when they're on sale. Would you believe the AS ZPs were only sold in North America
I'm not sure Virgin Atlantic would be very happy if I checked in a set as hold baggage.
