Anyone seem to have 4-5 gallons left once the car is on about drop dead empty...Seems like maybe a racing feature or something?? Ive driven semi long distances on empty and still only filled about 15 Gal into an 18 gal tank??????
I already have sent a few bottles through since I bought it... Maybe its gotten better, I dont know. It works for me tho as long as it wont serve any major issues in the future....
What are the symptoms? Does it drop normally to "E" but then drive for a long time with that reading. Does it drop to E early? Does the range figure in the DIC when it reads empty give a low reading or is it reasonable? The sender feeds to info to the gauge so chances are they'll agree. When you fill up does it go all the way to full?
Do the DIC warnings operate normally? Theres a fuel Low" caption that comes on when the needle gets close to "E". On mine that triggers at about 60 miles remaining. With Range selected you'll get "Range Low" caption at 30 miles. Are these captions coming on?
Mind you, the guys could be spot on and its the fuel sender thats toast. I've seen a few variations on gauge errors with a fouled up sender posted here over the years.
