Paint code.Magnetic red.
Old Aug 9, 2008 | 09:05 PM
396375's Avatar
396375
St. Jude Donor '08-'09
Default Paint code.Magnetic red.
My 2000 C5 was repainted a different colour other then stock before I bought it.It's magnetic red which is almost a burgundy.Not the bright red.Does anyone have the paint code so I can get some touch up paint?
Thanks guys.
Old Aug 9, 2008 | 09:25 PM
Optimus_C5's Avatar
Optimus_C5
From: If opportunity doesn't knock, build a door. South West Florida / Livin' The Dream
St. Jude Donor '12
my 2002 Magnetic Red II paint code is 86U
Old Aug 9, 2008 | 09:27 PM
02MillenniumVette's Avatar
02MillenniumVette
http://corvetteactioncenter.com/spec...2000specs.html
MR.WaynesWorld's Avatar
MR.WaynesWorld
From: The real question is; When you turn your car on, does it return the favor..
Cruise-In VIII & IX Veteran
St. Jude Donor '07-'08
Mine too...
Old Aug 9, 2008 | 10:32 PM
av8or's Avatar
av8or
Just this week I bought a can of GM touchup paint for my Mag Red C5 from the local Chevy dealer. GM part number is 12371340. The code on the can is 86/379E.
Old Aug 10, 2008 | 12:21 AM
396375's Avatar
396375
Thanks Guys.
Old Aug 10, 2008 | 01:24 AM
GrayC5's Avatar
GrayC5
86U is the RPO Code. The "WA" paint code for Magnetic Red II is 379E as shown at the following links:
http://www.corvetteactioncenter.com/...2002specs.html
(Note: the 2000 specs above refer to it as "Red Tint tri-coat")
Your car's "WA" paint code will also be listed on the Service Parts Identification Label on the inside of the glove box lid. It should be at the bottom of the label directly after BC/CC which stands for Base Coat/Clear Coat and should show "U 379E" for Magnetic Red.
In the following example, "382E" is the paint code for this car which is painted Pewter Metallic:
Service Parts Identification Label:
Old Aug 10, 2008 | 02:07 AM
DeeGee's Avatar
DeeGee
I bought a touch up from paintscratch.com. Its descrbed as Red Tint Metallic Tri Coat and the code is 86/WA379E. As the name suggests you get a base coat and color coat and clear. I've used it on stone chips and its a good match.
http://www.paintscratch.com/cgi-bin/makepaint2.cgi
Just a thought but if your car is an after market paint job you need to make sure they didn't use the 50th Anniversary Edition color which is more of a burgundy than the Mag Red II. Look at the pics of mine in my profile below. The sun makes the color look different. mag Red normally looks like the pic on the left. The bright sun in Vegas makes the car look a little more like the 50th color although the 50th is maybe a few shades darker than that.
Old Aug 13, 2008 | 08:11 PM
396375's Avatar
396375
Thanks guys.I ordered the touch up paint from GM.I bought a cheap air brush kit and it all came out great.
Take care.
To Paint code.Magnetic red.
