1998/2000 C5 Differences
Old Aug 11, 2008 | 07:04 PM
VeroWing's Avatar
VeroWing
Default 1998/2000 C5 Differences
Hi, I'm looking at purchasing a low mileage 6spd targa C5, in the pewter color. I've found two real nice low mileage examples. One is a 2000 with 18,000 miles for 25,000, and the other is a 1998 with 25,000 miles for 22,000. I cannot see any difference between the two, other than the 2000 has side moldings. Is there any differences that would make one of these models a better choice than the other, other than saving 3,000? I would appreciate any learned opinions on this. Thanks, Mike
Old Aug 11, 2008 | 07:16 PM
WKMCD's Avatar
WKMCD
If you don't intend to modify it save the money and buy the 98. Then again, the 2000 will always be worth more at resale time.
The main differences in the years are fairly minor and transparent to the average user. The 98 uses paper blocker rings in the tranny. Not to worry about those really - they wear like iron according to Rodney at RPM transmissions and they've held up fine on my transmission. The other change is in the PCM. In 99 they upgraded the PCM ( the main engine computer) to a faster processor and more refined tuning tables. Not an issue unless you intend to put a big cam in there and still only a small issue.
Now I do believe the 2000's had an oil buring issue around the rings. Maybe others will pipe in about that. You'll want to see if that car had/has it and whether it been covered under warranty already.
My $.02
Kevin
Old Aug 11, 2008 | 07:34 PM
VeroWing's Avatar
VeroWing
Thanks for that information Kevin. Its just what I'm looking for. Anyone else have any opinions on this? Thanks, Mike
Old Aug 11, 2008 | 07:52 PM
teagueO's Avatar
teagueO
Does the 2000 have a heads up display?
Old Aug 11, 2008 | 07:56 PM
VeroWing's Avatar
VeroWing
I'm not sure. I'll have to check.
Old Aug 11, 2008 | 07:58 PM
LoneStarFRC's Avatar
LoneStarFRC
Yes. It was an available option.
Oops. I see you were asking him about the 2000 he's considering.
Old Aug 11, 2008 | 08:00 PM
VeroWing's Avatar
VeroWing
The 2000 has heads up display, and I'm not sure about the 1998. They both have Z51 option.
Old Aug 11, 2008 | 08:01 PM
1slowFRC's Avatar
1slowFRC
Go with the 2000 for resales sake...or wait awhile and get an 01 so you can already have the ls6 intake!!!
Old Aug 11, 2008 | 08:05 PM
VeroWing's Avatar
VeroWing
Would the LS6 intake be a substancial improvement over the 1998/2000?
Old Aug 11, 2008 | 08:07 PM
Wombat24's Avatar
Wombat24
Don't forget the issues with the tac/traction control module on the 97 & 98's! I would check and make sure that issue has been fixed. I know my 97 had problems in this area and it was quite an annoying issue. For that narrow of a price difference I would go with the 2000 unless the 98 had more major mods.
dobewillie's Avatar
dobewillie
generally the later year car you can afford will be better for you in the long run
Old Aug 11, 2008 | 08:19 PM
VeroWing's Avatar
VeroWing
I'm at my limit now to as what I can afford, actually a bit past it, but what the heck. I'm going to go check both cars out tomorrow, and will probably pull the trigger on one or the other. Two last questions, do you think that those prices are in order for these low mileage cars, and, are there any particular items I should be checking when I look at these cars? Thanks, Mike?
Old Aug 11, 2008 | 11:00 PM
ROJ#79's Avatar
ROJ#79
Old Aug 12, 2008 | 02:48 AM
lucky99's Avatar
lucky99
i would look around sounds a little high, there was a 04 coupe in the for sale section 13,000 miles for 25,500
Old Aug 12, 2008 | 06:44 AM
VeroWing's Avatar
VeroWing
Thanks all for the advise. I think I'll hold off buying one of these two, and look for a newer model. Thanks again, Mike
Old Aug 12, 2008 | 07:33 AM
James 91Steelblue's Avatar
James 91Steelblue
I would keep looking. There are better deals out there. My 02 convertable is about $25,000 per KBB. 40,000 miles. If you can find one in your area.
Old Aug 12, 2008 | 10:36 AM
VeroWing's Avatar
VeroWing
Thanks James, I think you're right. Mike
To 1998/2000 C5 Differences
Old Aug 12, 2008 | 10:53 AM
Independent1's Avatar
Independent1
St. Jude Donor '08
Here is a site with a lot of info you will find helpful.
http://www.corvetteactioncenter.com/specs/
Good luck in your search!
Old Aug 12, 2008 | 01:50 PM
Herringchoker's Avatar
Herringchoker
From: "Man been singin' the Blues, since he began to till the ground"...Vancouver, USA WA.
No key hole, pass.side door on 2000, and If I'm not mistaken, the oil/rings issue was with pre 2000. JOE
Old Aug 12, 2008 | 02:45 PM
booker5m's Avatar
booker5m
I just got a 98 had 28900 miles and got it for $18500. Looks brand new. Give you an idea on prices
