Hi there,
If you are sure you were on a flat road, then take it back the guy goofed on the alignment specs.As the other poster stated balance is a vibration felt in the s/wheel at a certain speed.
Keep us updated.
robsc501
Make sure the road is level. Did the previous tires have any alignment wear? If the road was level or crowned towards the center you have a radial pull, cars generally pull left due to road crown. Normally we would swap tires from side to side to determine if it is a radial pull. Corvettes are a little more difficult due to asymetrical or directional tires.
