Shifters
My brother has the Hurst in his vette (previous owner install) but he wishes the owner would have done the B&M ripper.
The **** believe it or not makes a huge difference for me. It looks great but works even better with the aftermarket shifter. Together the pair make banging gears more fun!
The shifter itself just doesn't start getting harder to engage.Your problem may not be shifter related at all.
Do a search in the forum for "hard to shift". You will find his post (attached below) with a diagram of what is being refered to.
1] Apply the parking brake.
2] Remove the shift control closeout boot. Refer to Shift Control Shift Closeout Boot Replacement .
3] Place the shifter into NEUTRAL.
4] Press down to engage the shift control neutral lock pin.
5] Loosen the transmission shift rod clamp bolt.
6] Loosen the shift control mounting bolts.
7] Check that the shift control locator (on the underside of the shift control) is installed into the shifter bracket on the side of the driveline support assembly.
8] Tighten the shift control mounting bolts. Tighten the shift control mounting bolts to 30 N·m (22 lb ft).
9] Tighten the transmission shift rod clamp bolt.
Tighten the transmission shift rod clamp bolt to 30 N·m (22 lb ft).
10] Lift to release the shift control neutral lock pin.
11] Install the shift control closeout boot. Refer to Shift Control Shift Closeout Boot Replacement .
12] Release the parking brake.
Good luck!
