Kwik-Lift Storage Solution - PICs
Old Aug 25, 2008 | 11:24 PM
Choreo's Avatar
Choreo
Default Kwik-Lift Storage Solution - PICs
This is a follow-up to my post earlier this month...
http://forums.corvetteforum.com/show...ight=kwik+lift
My problem was how to store the Kwik Lift with the following requirements so that I could keep the garage floor area as open as possible when not in use:
(1) Had to be safe for custom tile floor
(2) Had to be stored and assembled by ONE person without help.
(3) Maintain minimum amount of time to set-up and tear-down (10 min)
(4) Store in the minimum amount of space possible for quick assembly
The main solution was to make some custom-built lightweight aluminum (black powder-coated) stacking blocks. These allow the second rail and all other components to be stacked vertically so that the whole stored assembly only takes up one rail width. As you can see by the 8" tiles - only takes up 20" in widtgh.
Very happy with results...
Old Aug 25, 2008 | 11:43 PM
Kale's Avatar
Kale
Cool! I can't wait to get mine. Been waiting a month.
Old Aug 26, 2008 | 03:37 AM
BATM4N's Avatar
BATM4N
Very Nice But where did you get the non-slip stuff that your tire rides over in pieces that long?
Old Aug 26, 2008 | 05:27 AM
csexton's Avatar
csexton
Looks great
Chuck
Old Aug 26, 2008 | 06:12 AM
bowtiebubba's Avatar
bowtiebubba
I need to know also.
Old Aug 26, 2008 | 06:29 AM
Choreo's Avatar
Choreo
Got it from the Tape Depot...
http://www.thetapedepot.com/cart/com...mart/Itemid,1/
20 yards - 4" wide roll - $50.60
One Roll was all I needed. BTW - make sure to clean the surface with alcohol or paint prep before applying or it will come off where you chock the tires.
Old Aug 26, 2008 | 10:15 AM
Nice solution you came up with.
Old Aug 26, 2008 | 10:25 AM
THE TECH's Avatar
THE TECH
Any pics of it in use?
Old Aug 26, 2008 | 11:02 AM
peter pan's Avatar
peter pan
Life Time NCM #2196
Sweet
Old Aug 26, 2008 | 12:17 PM
sprinter1104's Avatar
sprinter1104
Thanks for posting. I've been trying to find that tape (at a reasonable price) for some time.
I see that you have mounted casters on the bottom of the rails also.
Nice job.
Old Aug 26, 2008 | 02:11 PM
Choreo's Avatar
Choreo
Yes, if you will click the link in the initial post, it will take you to those photos.
Old Aug 26, 2008 | 02:14 PM
Choreo's Avatar
Choreo
Nice job.
Yes, the casters are explained in the link provided in the first post. They were necessary for "one person" to be able to roll them across the tile floor easily without doing any damage to the tiles - also makes lining up/inserting the torque tube much easier.
Old Aug 26, 2008 | 02:40 PM
THE TECH's Avatar
THE TECH
How much was it?
Old Aug 26, 2008 | 02:44 PM
hotwheels57's Avatar
hotwheels57
Nice job.
Try McMASTER-CARR for that tape. Or, do an internet search. Use keywords like "stair tread tape" or "slip resistant tape" or "skate board tape", etc.
I see a good opportunity for an after market product with the original posters idea. Maybe, directly with KWIK LIFT or one of the other forum vendors.
Old Aug 26, 2008 | 04:33 PM
Choreo's Avatar
Choreo
How much was it?
If you mean the lift itself, the prices are listed on their site...
http://www.kwiklift.com/
All of the other things I added are optional or not necessary for the average garage use...
• Non-Skid Tape (from Tape Depot) - $50
• (4) HD Rubber-Roller Casters and (4) Locking HD Rubber-Roller Casters (from Caster City) plus bolts/washers (from Lowes) about $120.00 + 2-3 hours to position and drill holes for mounting. Lots of things to consider when locating casters as they cannot touch floor with lift in the drive-on position.
• Lightweight Custom Aluminum/Powder-Coated Stacking Blocks (several hundred dollars if you do not have an inside source like I did), but you could make some out of wood for next to nothing.
To Kwik-Lift Storage Solution - PICs
