Painted Hood Liner
Old Aug 28, 2008 | 10:03 AM
striper's Avatar
striper
Default Painted Hood Liner
Has anybody painted their hood liner? I want to buy a new one and do some artwork on it. I'd like recommendations on the type of paint to use.
Old Aug 28, 2008 | 10:19 AM
DeeGee's Avatar
DeeGee
I posted this up a while ago. I used straight flat black BBQ paint from Home Depot. I used that for better resistance to heat but I'm not sure the temperatures get that high.
Refurbishing a Corvette C5 Hood Liner
The liner is made of a very delicate material so be careful in how you handle it once it’s removed. The surface is a fabric type finish and hard brushing will cause it to become rough and fibrous. It will also crack easily if you let it flex so if you take it outside beware of strong wind.
As you take the final fasteners out, support the liner so you don’t crack the liner around the eyelets.
The actual work takes only minutes. The drying time is the only slow process.
As you can see, the liner will have attracted quite a bit of dirt and grime.
OK here we go.
Lift the hood.
Remove the fasteners gently, top, then bottom and middle ones last. This will support the liner better as you take them out. Us a tool with a forked end. I’ve heard of a barbeque fork being used. I used a nail puller work in behind the fastener.
Take the liner outside and brush the surface gently with a soft brush to remove any dirt. Take care not to damage the surface of the liner.
Spray the liner with black paint. The difference between the old and the new surface is immediately apparent.
Use as many coats as you see fit. The liner is porous so it will take at least 3 coats to get good coverage. Leave it for 30 mins between coats to allow the paint to dry.
If you plan to paint the Corvette emblem, you may wish to apply extra paint around the embossed area on the liner. This will stop the liner absorbing the coloured paint.
Once the paint is dry (and you may wish to leave it overnight), you can either paint the emblem or apply a decal. I chose the decal. Alternatively if you prefer, you can refit the liner and apply the decal when it’s back in place.
Refit the liner in the hood fitting the middle fasteners first to hold it in place, then refit the remaining fasteners. A gentle push fit is all it takes to reinsert the fastener.
The finished Hood Liner
Old Aug 28, 2008 | 10:52 AM
tony car4a's Avatar
tony car4a
Nicely done DeeGee! Guess I'll be buying some paint this weekend.
Old Aug 28, 2008 | 10:56 AM
need4speed1's Avatar
need4speed1
Very ! Thanks for the info and write-up
Old Aug 28, 2008 | 11:03 AM
C5C6Norm's Avatar
C5C6Norm
From: Lower, Slower Delaware, formerly from Mobtown, MD (Baltimore)
Used Dupli-Color Auto Carpet & Fabric paint.
Old Aug 28, 2008 | 11:22 AM
bucwheat's Avatar
bucwheat
Nice job posting DeeGee
Old Aug 28, 2008 | 12:06 PM
Jims2001's Avatar
Jims2001
I just used spray cans and model brush on paint after spraying it black.
Old Aug 28, 2008 | 12:16 PM
Noel@AutoBuffs's Avatar
Noel@AutoBuffs
Former Vendor
St. Jude Donor '09
We use all base coat colors, some guys use water based but I would not recommend that for obvious reasons.
Old Aug 28, 2008 | 02:16 PM
Shirl's Avatar
Shirl
2025 C8 of the Year Finalist - Modified
2021 C7 of the Year Finalist - Unmodified
Looks good! How did you mask the checkers off to get them perfect?
Old Aug 28, 2008 | 02:37 PM
ggeldy's Avatar
ggeldy
use tester paint pens
Old Aug 28, 2008 | 04:59 PM
mtwalet's Avatar
mtwalet
WOW!!! NICE!!
JPD53012's Avatar
JPD53012
Does anyone know were DEE GEE got the decal
Old Aug 28, 2008 | 07:36 PM
OhioDave's Avatar
OhioDave
St. Jude 15 Year Donor
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16'17-'18-'19-'20-21
This link shows a Liner from the Canadian Section. Corrado does some amazing work.
http://forums.corvetteforum.com/show....php?t=2107282
Old Aug 28, 2008 | 07:46 PM
Cozmo's Avatar
Cozmo
CentralTX Events Coordinator
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17
Painted mine like Dee Gee and installed a decal that I bought from that big auction site.
Old Aug 28, 2008 | 08:44 PM
dobewillie's Avatar
dobewillie
great post all lookin very sweet
Old Aug 29, 2008 | 02:13 PM
DeeGee's Avatar
DeeGee
I got it from RPI Designs
Old Aug 29, 2008 | 02:39 PM
02MillenniumVette's Avatar
02MillenniumVette
Thats how I did mine.
To Painted Hood Liner
Old Aug 29, 2008 | 03:59 PM
Razorback58's Avatar
Razorback58
Very nice work!
Old Aug 29, 2008 | 04:12 PM
RayCE's Avatar
RayCE
Old Aug 29, 2008 | 09:11 PM
renegad44's Avatar
renegad44
From: This is not a Song, It's an Outburst: Or, The Establishment Blues; Sixto Diaz Rodriguez
I did the work myself, but I'm not sure if I'm completely satisfied with the way it came out, I'm posting it anyway.
