2002 power windows
Old Aug 28, 2008 | 05:01 PM
rgaiser's Avatar
rgaiser
2nd Gear
Default 2002 power windows
Does anyone have any knowledge of problems with power windows with 2002 vetts and what the fix is ??
Old Aug 28, 2008 | 05:16 PM
JUSTAKAR's Avatar
JUSTAKAR
Default windows
What's the symptom?
Windows lower but do not go up or nogo up or down???
Old Aug 28, 2008 | 07:02 PM
Bakersfield's Avatar
Bakersfield
All C5 model years seem to have problems with the passenger door window. Easiest fix is to turn the key on, sit in the passenger seat, hold the window down button, and slam the door closed hard until the window works again. If that doesn't do the trick, remove the door panel, remove the speaker assembly, take a small hammer and tap on the motor (regulator) housing. If that fails to resolve the issue, replace the regulator. But we seem to have about a 95% success rate with slamming the door closed. Good luck.
Old Aug 29, 2008 | 02:17 PM
zee_oh_six's Avatar
zee_oh_six
Are both windows inoperative or just one?
Old Aug 29, 2008 | 03:35 PM
Tom/99's Avatar
Tom/99
I had to have both power window motors replaced on my 04 coupe.
Old Aug 30, 2008 | 09:18 AM
rgaiser's Avatar
rgaiser
2nd Gear
Default windows
Both
Old Aug 30, 2008 | 09:24 AM
DeeGee's Avatar
DeeGee
Originally Posted by rgaiser
Both
Strange if both are out
Try fuses first:
30 (10A) and 31 (25A) for the right
33 (10A) and 34 (25A) for the left
Both in the footwell
Failing that check the connectors in the door hinge bellows. They can become loose and stop all functions. If, not, as Bakersfield suggests you're into door module problems.
To 2002 power windows
