Valve Spring Question
Old Sep 1, 2008 | 12:31 PM
96mogt's Avatar
96mogt
Default Valve Spring Question
I was on the phone with a distributer because i was interested in a set of next valve springs for my cam swap. He stated that since my cam was a 588 lift cam to go with a 600 lift spring which is fine. But he said that the springs wont work because i would need to have the seats milled down to accept the 600 springs. I have never heard this at all with all the cam swaps ive read on this board. It does make sense to do it, but im not tearing off stock heads just to have them milled and throwing them back on. Ill just opt for a new set of aftermarket heads. Man this throws a wrench in my cam only swap. Whats your guys\gals imput on this? Jay
Old Sep 1, 2008 | 12:44 PM
10U 99's Avatar
10U 99
St. Jude Donor '08-'09
very common when getting into that much lift. the last thing you want is coil bind
Old Sep 1, 2008 | 12:54 PM
96mogt's Avatar
96mogt
HHhhmm.. I guess its no beuno on the cam only swap
Old Sep 1, 2008 | 01:18 PM
Fasthotrod's Avatar
Fasthotrod
I thought that the Comp Cams beehive springs were good for over 0.600 lift and didn't require machine work?!?!
Check these out from Lingenfelter:
http://www.lingenfelter.com/Merchant...Store_Code=LPE
Hope this helps.
Mark
Old Sep 1, 2008 | 01:59 PM
WKMCD's Avatar
WKMCD
Just throw in a set of PRC Duals or Patriot Golds and be done with it.
Old Sep 1, 2008 | 02:27 PM
Last C5's Avatar
Last C5
The nitrated PAC 1518 beehive springs are good for .650 lift and they drop right in.
Old Sep 1, 2008 | 02:48 PM
96mogt's Avatar
96mogt
So than i dont have to worry about milling the stock heads?
Old Sep 1, 2008 | 02:51 PM
96mogt's Avatar
96mogt
Thanks for the info guys. Im going to get a set and do the install. Jay
To Valve Spring Question
