Meltdown! Seriously.
Old Aug 31, 2008 | 04:12 PM
phoenixfoundmac's Avatar
phoenixfoundmac
Default Meltdown! Seriously.
Car was fine. Now car is not fine.
Yesterday I took my car out(04, mn6, bolton mods, only 7500 miles) for a quick spin without issue. Afterwards I decided to wash it. After a typical washing of the exterior I went to start the car and things went haywire. The car will crank and fire for half a second and immediately die. The power windows don't work, the power locks and mirrors do not work, the radio does not work, basically none of the power accessories. The DIC is currently flashing reduced engine power, low fuel, shocks inoperable(magnetic selective ride), service vehicle soon. When I access the onboard diagnostics it only says "no comm." after every subheading. I also hooked up a handheld obd2 scanner and it just flat out wouldn't read. So I took the wheel well cover off of the passenger front to inspect the computer(PCM) and it wasn't soaked in there, but there was a little water. I didn't do anything different washing my car, just a routine exterior wash. Call me crazy, but I think my computer is fried. If that's the case what is my next best move. Sorry about the length of this post.
PS. - Car is currently safe in my garage. I was able to push it in from the driveway.
Old Aug 31, 2008 | 04:16 PM
DeeGee's Avatar
DeeGee
You car is showing classic dead battery symptoms. Not surprising with a low mileage 04
To check your battery voltage, do not read the DIC when the car is off. The voltmeter is designed to measure alternator output when the car is running. It will always measure an inaccurately low voltage on the battery when the car is off. Anything from 11.0-11.9 is not abnormal in this mode. With the engine on, the voltmeter should show between 13V and 14.5V. A better reading can be measured at the battery terminals. Use a digital multi meter if you can. A fully charged battery measures approximately 12.66 V and a fully discharged battery measures about 11.86 V.
A recharge or a new battery will probably fix it.
Old Aug 31, 2008 | 04:20 PM
Patches's Avatar
Patches
I would check the battery - this sounds similar to that sudden wigout many of us here have experienced when the battery crosses that mysterious line and has enough voltage to register certain functions and go insane on the rest.
I'd have the battery load-tested to see if it's viable and check to see if it dropped a cell.
madmatt9471's Avatar
madmatt9471
From: Palmdale, Ca----- 2009 Cyber Gray 4LT A6 F55 452 RWHP 422 RWTQ- RIP 1998 C5 734 RWHP & 585 RWTQ-----
It seems as if something got wet that should not have!
I will suggest to take a close look at all your grounds because it sure sounds like a bad ground connection.
Check the CODES if you can access them and let us know what you get!
It will not be suprising to see that a ground has gone bad.
Thanks,Matt
Old Aug 31, 2008 | 04:38 PM
phoenixfoundmac
That's what my instincts said. I already replaced the battery and there is no change in conditions. The old battery was the original and I it had been cranking slow so I figured what the heck. The new battery had absolutely no affect. And as I said before I cant get the diagnostics to say anything other than "no comm." It doesn't give any current or history codes nor does it say no more codes, just no comm. I also tryed a handheld scanner and it could not communicate with the car, it just repeatedly froze up.
Old Aug 31, 2008 | 04:40 PM
DeeGee's Avatar
DeeGee
If you checked the voltage across the terminals and its good, I'd be looking at the battery leads and the grounds. The fact that there are so many unrelated issues there makes me think electrical system.
Maybe not the problem but check the rubber bellows in the door hinges. Its been known for water to get in there and cause problems if the connections are loose.
Old Aug 31, 2008 | 04:44 PM
Vegas Vette's Avatar
Vegas Vette
Reduced engine power warning is a PCM problem. At least that was my experience after a tune. I think its the PCM also
Old Aug 31, 2008 | 06:08 PM
Jnape's Avatar
Jnape
BCM also with the selective ride errors. Grounds more than likely
Old Aug 31, 2008 | 06:09 PM
Bill Dearborn's Avatar
Bill Dearborn
If you got water in the data link connection (door wiring) and it is shorted to ground that can cause the symptoms you are seeing. That would explain the No Comm messages.
Bill
Old Aug 31, 2008 | 06:57 PM
Patches's Avatar
Patches
So far, we have given you all the usual suspects - battery, grounds, PCM, door bellows . . . Typical when one of these monsters rears its ugly head.
The car wash may be just a coincident but I wouldn't rule anything out. I always work through in the sequence where I don't start changing parts until I've run out of diagnostic routines or something leads me to conclude a hardware failure is to blame.
Old Aug 31, 2008 | 06:58 PM
phoenixfoundmac
If I get it dry do you think it will return to normal operation?
Old Aug 31, 2008 | 07:02 PM
Chicago1's Avatar
Chicago1
You talking about the pcm? If nothing is fried then maybe and you need to take that car out more and enjoy it. Not good when you let things sit for so long.
Old Aug 31, 2008 | 07:49 PM
WildTurkey's Avatar
WildTurkey
I cant offer anything from my knowledge/experience, BUT definitely good luck with this....I hope you find a fix
Old Aug 31, 2008 | 09:08 PM
watsonsvett's Avatar
watsonsvett
i had the same exact thing happen to me and it turned out my pcm fried. i pulled mine out and checked it and found corrosion on the connections. you try that yet?
Old Sep 1, 2008 | 02:35 AM
DeeGee's Avatar
DeeGee
If it's water and not a coincidental failure, as it dries out the fault would probably clear. The problem is where did the water get in? Did you use a pressure washer? If not, it's likely to be the doors IMHO.
As Patches says, be logical. Start with the easy stuff.
Check the battery voltage
Disconnect the door bellows connectors and clean them up and dry them out. Some dielectric grease will help.
Check the grounds. The one on the engine side bulkhead behind the passenger headlight is a good start.
Only at that point do you want to start playing with other hardware such as PCM/BCM (major jobs).
You have the best of the Forum electrical gurus helping you out (and I don't put myself in that category)
Old Sep 1, 2008 | 03:26 AM
Oh 2 Fun's Avatar
Oh 2 Fun
St. Jude Donor '09, '13, '15
You folks are great.....good advice from all ...and it's free......
Hope it's helped......sharing the experiences is good for all of us.
thanks!!
Old Sep 1, 2008 | 11:51 AM
phoenixfoundmac
First off I'd like to thank everyone for their responses. I checked everything that was suggested. The car is 100% back to normal(hopefully it stays that way). The harness that plugs into the bottom of the pcm was damp and the little rubber seal that is supposed to protect it was krinkled. After unhooking everything and blow drying it out the car returned to perfect working order. The only thing I can figure is the side cove cover is a little loose and water was getting in behind it and enough finally got in to cause a problem. I can't find any other cause. Happy for now though. If this problem rears it's ugly head again I know where to turn as always.
Old Sep 1, 2008 | 01:29 PM
Toque's Avatar
Toque
From: Wylie TX --> Less is More, except under the hood !
Good to hear you got it figured out ! PHEW !!!!
Toque
Old Sep 1, 2008 | 03:03 PM
damilleniumboy's Avatar
damilleniumboy
To Meltdown! Seriously.
