2001 ragtop problems
Old Sep 1, 2008 | 12:54 PM
bretts ragtop's Avatar
bretts ragtop
1st Gear
Default 2001 ragtop problems
I just purchased a 2001 ragtop, so I will probably have a lot of future questions. Right now one of my concerns is fact that the the back of the top that is supposed to rest on the rubber seal on the rear deck is contacting the paint. The contact point is at the seams of the fabric. I can touch up these spots, but I was wondering if there is an adjustment of the top that would prevent this from continuing to happen.
Thanks, Brett
Old Sep 1, 2008 | 02:16 PM
Lafd4me's Avatar
Lafd4me
The make protective clear and colored protective strips, Deck Lid Paint Protectors that you lay over your paint in that area to prevent it from damaging your paint. I'm sure a few of the Forum Vendors sell them. They are pre-cut to run all the way around the outside edge of that black rubber seal. As far as an adjustment Im not sure but someone will soon answer that for you....
Old Sep 1, 2008 | 02:24 PM
silverhaired daddy's Avatar
silverhaired daddy
I have the same problem, even after installing a brand new top. Disregard my picture I have my hadtop on.
zx14's Avatar
zx14
Quote:
Originally Posted by LTCHAPPA
There is an adjustment on the top to take care of that problem
Here is a link to the top adjustments:
http://www.c5forum.com/cgi-bin/ultim...ic/1/2213.html
Old Sep 1, 2008 | 02:27 PM
Sully C5's Avatar
Sully C5
Cruise-In II Veteran
Here is a link regarding all the improvements made in 2001
http://www.corvettemuseum.com/specs/2001/index.htm
To 2001 ragtop problems
