Tire Pressure Sensor
Old Sep 2, 2008 | 08:41 PM
ALVETTE00's Avatar
ALVETTE00
Default Tire Pressure Sensor
The other day the DIC said something like...Service Tire Monitoring System then went away.
Haven't seen it appear since.
Is that a fluke, or is that an indication that they should be replaced.
Car is a 2000.
Thanks,
al
Old Sep 2, 2008 | 08:42 PM
jacks996's Avatar
jacks996
Jacks996
Cruise-In VIII Veteran
mine has said it and then went away. do you show pressures for all 4? I have a 2000 also
Old Sep 2, 2008 | 08:47 PM
ALVETTE00's Avatar
ALVETTE00
Yup...and they're still accurate!
Old Sep 2, 2008 | 08:48 PM
ALVETTE00's Avatar
ALVETTE00
Also, gonna be swapping the rims - so I wonder if I should swap the sensors regardless given their age?
Thoughts
Old Sep 2, 2008 | 08:53 PM
Bill Vett's Avatar
Bill Vett
Yes replace them all.They're at the end of their life span. No sense risking damage to your new wheels or tires replacing them later.
Old Sep 2, 2008 | 08:54 PM
Oldvetter's Avatar
Oldvetter
Thoughts
1997-2000 TPMS are supposed to last 7 years or 100,000 miles. If yours are original, they should be replaced if you change rims. They have a date stamp in the plastic showing date they were made (circles with arrows pointing to numbers).
Buy from Gene or Frictner's, they are cheapest at ~$90 each.
Old Sep 2, 2008 | 09:28 PM
ALVETTE00's Avatar
ALVETTE00
Will Do
Is changing them a pain in the ****? Anyone have a how to?
Old Sep 2, 2008 | 10:56 PM
jrose7004's Avatar
jrose7004
If they're not broke don't fix them!
Old Sep 2, 2008 | 11:32 PM
rws.1's Avatar
rws.1
your batteries are dying. As temperatures drop as we approach autumn, the message will appear more frequently.
The tire needs to be dismounted or at least the bead broken and the side wall depressed so the old TPMS can be removed and a new one inserted.
Many tire shops will not do this without removing the tire because the depressing the side wall approach is not safe for the technician. Should something happen and the tire slip away from the machine, the tech could lose his hand.
Old Sep 3, 2008 | 10:02 AM
Bakersfield's Avatar
Bakersfield
ALVETTE00, I can change out the batteries in your sensors and save you a bunch of money. I will send you a PM to explain.
Old Sep 3, 2008 | 10:39 AM
bucwheat's Avatar
bucwheat
That sounds like the smart path,I have had mine since 1998 no problems.
Old Sep 3, 2008 | 07:02 PM
Bakersfield
I had to replace the batteries in my 98 last year. Keep me in mind when your ready.
Old Sep 3, 2008 | 10:30 PM
ALVETTE00's Avatar
ALVETTE00
Will the DIC automatically pick-up the new sensors signal, or is there some process associated with that?
Old Sep 4, 2008 | 07:40 AM
chreaponecoat's Avatar
chreaponecoat
Go with Dwayne (Bakersfield) on his offer, top notch work. Did mine, works great and saved lots of money. If you buy new they can still be old batterys. He puts up to date batterys in.
Old Sep 4, 2008 | 09:45 AM
Bakersfield
New sensors have to be "Learned" by the car. There is a procedure and I think it is in your owner's manual. If not, do a search in this forum and you will find it. When I get home from work, I will look it up if no one else beats me to it.
Thanks chreaponecoat for your indorcement.
To Tire Pressure Sensor
