Front Camber Alignment Issues
Old Sep 3, 2008 | 01:15 PM
christian79's Avatar
christian79
Default Front Camber Alignment Issues
I am trying to correct a slight negative camber issue with my 2001. The tech said that there is no additional adjustment left on the eccentric bolts. Are there shims available to reposition the upper control arm? The camber is not way out of spec but enough that I will wear the tire unevenly with out frequent rotations.
Christian79
Old Sep 3, 2008 | 01:27 PM
thehammer69's Avatar
thehammer69
Christian79
You can use washers to shim out the upper control arm on the front. But if you just have to have shims to do this, Pfadtracing.com sells a camber kit that has them.
I'm curious, what is your camber set at right now?
Old Sep 3, 2008 | 09:19 PM
lionelhutz's Avatar
lionelhutz
An alignment tech should already have shims that will fit because they're often used to adjust the alignment. Just put a few behind each of the 4 bolts on the upper arm and try aligning it again.
Peter
To Front Camber Alignment Issues
