Shock Install Help
Old Sep 3, 2008 | 02:28 PM
ALVETTE00's Avatar
ALVETTE00
Default Shock Install Help
Guys,
Searched some prior threads on this topic and have some questions.
This will be my first time doing this and want to see if anyone used these sites as guides:
http://www.c5forum.com/diy/shocks.php
http://fuzzydiceracing.com/test.htm
Are the steps accurate?
Also, in one thread, someone said they snapped the rear lower shock bolt when attempting to torque to 162ft-lb. I'm no expert, but man that seems like a helluva lot of torque! Is this accurate, I would think 75-100 would do the trick? Do you have to replace these bolts when replacing the shocks?
Thanks a ton.
al
Old Sep 3, 2008 | 03:31 PM
romeokc10's Avatar
romeokc10
I'm about to do the same, just bought some Bilstein Sports.
Old Sep 3, 2008 | 04:05 PM
ALVETTE00's Avatar
ALVETTE00
I went with 04 Z06...
Read lots of good things about both...was a tossup for me. I don't like the yellow/blue combo so went with the plain black Z06. LOL
Also, reading that the GM engineers tuned them specifically for the C5 was a plus.
Old Sep 3, 2008 | 04:50 PM
CCA Corvette Parts's Avatar
CCA Corvette Parts
Premium Supporting Vendor
St. Jude Donor '07-'08,-'13-'14, '16-'17
Those instructions will get you through the job fine.
The biggest thing I can tell you is to make sure you tie your shocks up real tight (compressed) before you remove the bolt...
Peace
Chip
__________________
..................Click for
Old Sep 3, 2008 | 06:33 PM
renegad44's Avatar
renegad44
From: This is not a Song, It's an Outburst: Or, The Establishment Blues; Sixto Diaz Rodriguez
Don't forget, Coronas are optional to your taste.
Old Sep 3, 2008 | 06:59 PM
stormrider's Avatar
stormrider
Those are the instructions I used to install my Konis last year they worked great. At least I think they did
Old Sep 3, 2008 | 07:37 PM
renegad44's Avatar
renegad44
Someone else did my shocks as a courtesy, but I did use the Corona's when I lowered it, and installed the sway bars.
Old Sep 3, 2008 | 08:32 PM
thefreeauction's Avatar
thefreeauction
Same here, my Bilstein's should be here on Monday. I plan on following those how-to's too. But I hope I don't have any problems if I subsitute Bud Light instead of Corona though.....
Old Sep 3, 2008 | 08:52 PM
71corv's Avatar
71corv
St. Jude Donor '08
Just installed the Bilstein shocks on my 2002 ZO6. Followed the directions listed above (fuzzydiceracing). Everything worked as diagramed. I did reuse the bolts on the rear shocks and didn't have any problem torqueing them to 162 lbs/ft. Use strong ties , the thin ones will break.
Gene
Old Sep 3, 2008 | 08:55 PM
ljthe2nd's Avatar
ljthe2nd
Following the steps in the 2nd link will get the job done. But you could make the job a little less work by just using a pry bar to compress the front shocks, instead of using a jack and all those zip ties. Once the bolts are removed from the front shocks just insert a pry bar under the bottom of the shock pry it up until compressed (holding it in the compressed position) and just wiggle it out. If you have a 2nd person it's easier but I did it myself without any help.
Old Sep 3, 2008 | 09:06 PM
DBS99MagRedCoupe's Avatar
DBS99MagRedCoupe
I had one of the rear shock bolts snap off trying to get to 162 ft lbs. The other one was no problem. Just bad luck I guess.
Old Sep 3, 2008 | 10:25 PM
ALVETTE00's Avatar
ALVETTE00
I'm NOT an engineer, but my gut tells me 162ftlbs is excessive!
Has anyone gone less than this?
I think I'll shoot for 100ftlbs!
To Shock Install Help
