DIY Oil Change C5
Old Sep 4, 2008 | 05:35 PM
paullywalnuts's Avatar
paullywalnuts
Default DIY Oil Change C5
Anyone have the link on DIY C5 oil change...since I will not be having the stealership do it for $70!! I saw one on here a while back and it had good photos..thanks.
Old Sep 4, 2008 | 05:53 PM
jdsaengine's Avatar
jdsaengine
I just changed the oil myself for the very first time. After 2 hr. dumping oil all over the driveway because the wind was blowing the dripping oil away from the pan (at least I had a plastic trash bag on the concrete) trying to get the filter off with a filter wrench that must have been 1/8" in diameter too big, couldn't get the plug off with socket wrench because cross member was in the way, and not really fitting under the front of the car (beer belly?) even though I just bought Rhino ramps at Wal Mart, . . . Maybe $70 would be worth it !!
Old Sep 4, 2008 | 05:58 PM
paullywalnuts
I was reading a site on how to do it..but it said to buy ramps and drive up on them..Im assuming I only need to ramp the front..which confuses me b/c it also said after you drain the pan..to jack up the rear 8 inches above the front so the rest of the oil can drain..seems like my rear end is gonna be jacked pretty high..is that correct?
Old Sep 4, 2008 | 06:02 PM
devnull's Avatar
devnull
Scientific Negotiator
St. Jude Donor '07-'08-'10, '14
Never let the dealership touch it!!! (or anyone for that matter)
Here is the link ---> http://97vette.com/howto/oil/index.html
Old Sep 4, 2008 | 06:03 PM
devnull's Avatar
devnull
Level is fine... Get two sets of ramps ad lower the rears onto the second set. Above level is marginally better, but not a big deal at all.
Or you could go all out...
Old Sep 4, 2008 | 06:09 PM
Quick Silver Z's Avatar
Quick Silver Z
St. Jude 15 Year Donor
No-IL Events Coordinator
2025 C6 of the Year Winner - Unmodified
2019 C6 of Year Winner (appearance mods)
2018 C6 of Year Finalist
St. Jude Donor '12 thru '26
Obviously if you have the expertise and facility to change your own oil do so. I myself was happy to watch a very capable local Vette mechanic do it for me. While up in the air I had the differential, transmission and coolant fluids changed. So as not to be called a complete wimp I replaced my own air filter element!
Old Sep 4, 2008 | 06:14 PM
34RedRage's Avatar
34RedRage
the only reason i change my oil myself is shown in the picture....
Old Sep 4, 2008 | 06:24 PM
Bill Seamon's Avatar
Bill Seamon
There was some jacking instruction I saw a while ago. They suggested jacking up the back of the car by placing some wood under the rear cross member and using a floor jack from the back of the car. Then place safty stands under the rear pucks. This raises the front enough to get a floor jack under the front cross member by going under the driver's door (between the front and rear wheel) to get to the front cross member. Then put safty stands under the front pucks and the car is up. I followed this procedure when I installed the shift lock out and changed the oil on my 2002 Z06 with no problems.
Old Sep 4, 2008 | 06:46 PM
paullywalnuts
Ok thanks guys..wish me luck.
Old Sep 4, 2008 | 07:14 PM
10U 99's Avatar
10U 99
St. Jude Donor '08-'09
dude, ask around at the dealerships for what they will charge if you bring your own oil & filter. mine does it for $9.50 and they allow me to inspect the undercarrage while it's in the air. and there are dealerships you can trust!
Old Sep 4, 2008 | 08:05 PM
Ikester's Avatar
Ikester
CI 6-7-8-9 Veteran
thats correct, get a set of rhino ramps for the front. then jack up the rear with a 2 1/2 ton floor jack. use the center rear cross member for the jack point. jack it up till the car is level then watch more oil drain out.
i dont use jack stands in the rear since i am not going under there.
Old Sep 5, 2008 | 02:00 AM
tbrent's Avatar
tbrent
2018 C5 of Year Winner
Thanks for posting this link!!!!!!!
Old Sep 5, 2008 | 07:22 AM
warren s's Avatar
warren s
[[IMG][/IMG]No dealer !!
Old Sep 5, 2008 | 07:31 AM
Doba's Avatar
Doba
how much does a hoist like that run for? thats awesome! whats the hight measure of that thing?
Old Sep 5, 2008 | 08:02 AM
paullywalnuts
I'll check on dealer...I would never imagine that they would be willing to let me bring in the supplies..I could surely deal with $9.50 plus oil and filter!
Old Sep 5, 2008 | 08:05 AM
paullywalnuts
BTW...I'm pretty impressed by those lifts!
Old Sep 5, 2008 | 08:15 AM
Oldvetter's Avatar
Oldvetter
You don't have to raise the back 8 inches over the front, just a couple will do.
BTW, raising the back only drains out 4 more ounces of oil. I do it, but you don't have to.
To DIY Oil Change C5
Old Sep 5, 2008 | 09:47 AM
devnull's Avatar
devnull
Hey thanks bud. They hover around $2k if you install it yourself (no big deal to do). It is 80" tall and will lift 7,000 lbs!
Best tool in the shed.
Old Sep 5, 2008 | 10:34 AM
Purdone's Avatar
Purdone
I did it myself without raising the rear. It was a mess when I pulled the filter out, but I caught most of it. I suggest an adjustable wrench for the drain plug.
Old Sep 5, 2008 | 12:04 PM
Mr.Bill's Avatar
Mr.Bill
From: Reno is so close to Hell you can see Sparks , State Of Confusion
St. Jude Donor '12-'13-'14
70 bucks, Thats a good price, It will take you some time to do it yourself, You have to jack up the front and rear and the rear has to be higher. For 70 bucks I would have the dealer do it, You are going to pay 60 bucks just for the oil and filter....
6.50 a qt = 45.50
1 filter 10.00
My time is worth a lot more than 10-15 bucks and no mess to clean up.
