Intrestingly enough the Hyperco front springs are the same spring rate as the stock Z06 spring hense Im only replacing the rear...
That is incorrect....
C5Z fronts are 526...Hyperco street fronts are 565...Hyperco Race Fronts are 625. That is basically a 100# increase for the race Hyperco.
I did the front Streets and rear Track. I also changed to Koni FSD shocks at the same time. Big improvement over stock, like em a lot. I had the car aligned and corner weighted at the same time, I was able to return to the same height that it was prior to installation.
