Question for convertible owners
Old Sep 6, 2008 | 11:37 AM
Bakersfield's Avatar
Bakersfield
Default Question for convertible owners
My wife's mustang convertible has a hydraulic oil stain from a leaking cylinder. What do you recommend to clean the stain off with? Thanks....
Old Sep 6, 2008 | 11:40 AM
blacksedan87's Avatar
blacksedan87
St. Jude 15 Year Donor
From: "It's 106 miles to Chicago, we've got a full tank of gas, half a pack of cigarettes, it's dark, and
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-‘18-'19
Is the top vinyl or cloth? It makes a difference? Also - you might trying asking the question in the CAR CARE forum......
http://forums.corvetteforum.com/forumdisplay.php?f=10
Old Sep 6, 2008 | 11:48 AM
Jet-Jock's Avatar
Jet-Jock
Try these folks they are the makers of RaggTopp. You could call them under contact info and see what they recommend. RaggTopp is recommended by the top manufacturers.
Wolfsteins
My beige top got two little spots of gear grease from the overhead garage door opener track on it. I used gasoline, solvent and then raggtopp cleaner. It still shows a small mark when the top is wet but when it dries it disappears. I have only recently respotted that area with raggtopp protectant because I scrubbed that spot over and over each time I washed it (weekly) and it took a while to get the grease out. I didn't want to be too aggressive with it and damage any of the fabric strands.
Yeah I forgot, about Ford using vinyl tops. What I described is for the cloth top but the link is still valid as they have products for the vinyl tops too. Thanks black...
Old Sep 6, 2008 | 11:58 AM
Bakersfield
It is a vinyl top. I will post this over in the car care forum, didn't think about that.
Old Sep 6, 2008 | 12:02 PM
Bakersfield
Wolfsteins
Thanks for the link to Wolfsteins. That gives me some good information to try. I appreciate the help guys.
Old Sep 6, 2008 | 12:57 PM
steve8's Avatar
steve8
I'd definitely give the raggtopp kit a try.
When applying the protectant, the second step, don't let any of that get on the finish. If you have a couple of old sheets around, let them hang out from under the top.
To Question for convertible owners
