Ok, I know this has been beat up badly but i cannot find this symptom anywhere. why would my sensors be sending the wrong pressure to my readout? 5pounds off!!! any ideas???
Did you recently have your tires rotated? You should also re-train your sensors. If you have XXX instead of a pressure reading, then you have a dead sensor. If that happens, PM me and I can save you some big money on sensors.
Given that its a straight RF system it should be easy to troubleshoot. The way it works is that each sensor transmits a signal to the RFA once the car's been moving for a few minutes. The RFA sends the individual signals for each sensor to the PCM for display. The RFA is shared with the fobs. Logically, if the fobs work, the RFA is good and the links to the computer are good. That brings you back to the sensors. If they are all out by 5psi it may be a calibration problem and a retrain sounds like a good idea (it probably is in any case). If only one sensor is wrong then its that sensor.
All that said, on a 98 you're reaching the end of the battery life so I'd plan to replace them soon.
Don't forget youre are the older sensors, which are unfortunately more expensive.
If you have aftermarket wheels without sensors, can you disable the system altogether?
You can program them out with a Tech II on the later cars. Some members have fitted sensors inside the rims with bands. A vendor just came up with a mounting kit to hold them onto the rim with a stud of some sort.
I just bought 4 new wheels with tires from Nate at CORVETTE GARAGE. One of my wheels driver rear reads XXX have reset it 4 times. so what if they are brand new??? or did I get boned ? e-mailed him today lets see if "CORVETTE GARAGE" makes good on it?????
