malfunctioning tail lights
Old Sep 9, 2008 | 09:25 PM
luckyirishguy's Avatar
luckyirishguy
Default malfunctioning tail lights
its not on my vette...but it shouldn't make a difference. the tail lights work but the brake lights do not. ( at night the tail lights are on but when i apply the brakes hey do no get brighter)
I know a fuse can be the issue. what are other problems that would cause this?
Old Sep 10, 2008 | 05:22 AM
wdtiger's Avatar
wdtiger
Have you tried changing the bulb?
Old Sep 10, 2008 | 07:35 AM
Bugaboo's Avatar
Bugaboo
so many times it's a ground issue?
Old Sep 10, 2008 | 07:16 PM
luckyirishguy
i will re check all the fuses bulbs and maybe see if its the brake switch
Old Sep 10, 2008 | 09:47 PM
ajg1915's Avatar
ajg1915
St. Jude Donor '08
It's proabably the switch down by the brake switch, maybe it got loose or it's bad.
Old Sep 11, 2008 | 01:38 PM
luckyirishguy
hopefully its just something simple i.e fuse, bulbs, switch
Old Sep 11, 2008 | 02:48 PM
AMRAAM's Avatar
AMRAAM
I had the same issue with my C5. I believe it originally had a bad connection at plug. The previous owner hacked up the harness. I ended up buying a whole harness
To malfunctioning tail lights
