i have a 99 frc. the front has the plastic holders for the round foglights with the air flow blocked off. Instead of payin 80$ for the z06 airflow kit can i remove those and cut out the extra plastic so air can flow in?
If so what is the easiest way to remove them?
I am going to drill 1" holes in mine when I ever get around to it. I have the ZO6 screens on so it really will not show but will let more air in.I didn't really think I would have to remove them....guess I'll find out.
Just drill some holes in them. If you want to take them out, you need to go in through the access panel under the front fascia. They are held in with several screws.
