Someone else started my car?????
Old Sep 10, 2008 | 09:26 PM
jmesox's Avatar
jmesox
Default Someone else started my car?????
When I start my car I turn the car to accessories and let the computers turn on and then start the car. I let someone else drive the car and he turned the key right to start position. The car started, but nothing electrical came on. No air, radio, gauges nothing worked. I turned the car off, took the key out and restarted it the way I do, everything worked. Is this related to the column lock recall they put in for my A4 transmission? Any ideas guys? HELP
John
Old Sep 10, 2008 | 10:14 PM
jetske's Avatar
jetske
John
Wow John, I never do that and have never had an issue like you described. Sorry, I'm no help... But I would like to see where this thread will go...
Old Sep 10, 2008 | 10:32 PM
Never heard of something like that happening as a result of the column lock issue. I'd say there are other problems.
Old Sep 10, 2008 | 10:46 PM
dobewillie's Avatar
dobewillie
somethings up
Old Sep 10, 2008 | 11:22 PM
Cozmo's Avatar
Cozmo
CentralTX Events Coordinator
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17
I've never heard of that either
Old Sep 11, 2008 | 12:11 AM
clayton1's Avatar
clayton1
Banned Scam/Spammer
Try it again, without going to acc first...maybe it was just a glitch.
Crazier things have happened.
Old Sep 11, 2008 | 12:20 AM
C5Vette168's Avatar
C5Vette168
St. Jude Donor '08
Probably just a glitch. I start my car using both techniques and have never had a problem like the one you described. Were you able to duplicate the problem?
Old Sep 11, 2008 | 02:26 AM
j0n's Avatar
j0n
I had that happen once...turned it on in one move and almost s*** a brick when oil pressure read zero, then I realized that nothing turned on. Turned the car off and then back on and everything worked again. Haven't had the problem since!
Old Sep 11, 2008 | 03:54 AM
jacks996's Avatar
jacks996
Jacks996
Cruise-In VIII Veteran
your car only likes YOU
Old Sep 11, 2008 | 04:25 AM
jrose7004's Avatar
jrose7004
Bizarre!
Old Sep 11, 2008 | 06:59 AM
7thson's Avatar
7thson
I had a car that did that. Something wrong with the ignition switch I bet. Try wiggling the key.
Old Sep 11, 2008 | 07:13 AM
Bugaboo's Avatar
Bugaboo
never really had that but I do hesitate before i hit the start position to let the computers do their thing.
Old Sep 11, 2008 | 07:28 AM
rws.1's Avatar
rws.1
I have never even thought about going to accessory before starting.....I always go straight to start and all the electronics always do what they should.
Old Sep 11, 2008 | 07:42 AM
leadfoot4's Avatar
leadfoot4
Active Streak: 90 Days
When I start mine, I usually hesitate a couple seconds at the "acc" position, but only to let the fuel pump get up to pressure. I've never had happen what the "jmesox" experienced.
Old Sep 11, 2008 | 08:09 AM
C5XTASY's Avatar
C5XTASY
Old Sep 11, 2008 | 08:12 AM
MIKE-C5's Avatar
MIKE-C5
St. Jude Donor '05-'06-'08
Very strange! !
Old Sep 11, 2008 | 08:20 AM
jmesox's Avatar
jmesox
Yes it happened twice thank for the help so far guys!!
John
To Someone else started my car?????
Old Sep 11, 2008 | 08:42 AM
C5 4 ME's Avatar
C5 4 ME
Old Sep 11, 2008 | 09:01 AM
Storm Cloud's Avatar
Storm Cloud
See if you threw a code and it went to history. I am going to guess IPC.
Old Sep 11, 2008 | 09:03 AM
wcsinx's Avatar
wcsinx
The [start] position shuts off the power to the accessories anyway.
I've never had the problem the OP describes, but I have noticed a sometimes variable delay between when the engine cranks up and the radio, ac, gauges, etc. turn on. Usually it's immediate, sometimes it's 4-5 seconds tops. I never really let it bother me.
