Catch Can
Old Sep 13, 2008 | 04:45 AM
vetteguy11's Avatar
vetteguy11
Default Catch Can
I run an STS twin turbo set up at 12lbs of boost and have high pressure in the crankcase because of the boost. Am putting in a catch can, or filter on the valve cover for the lay man. Has anyone else done this and is the stock hole big enough to vent properly or does it have to be enlarged? The company says the stock vent is big enough but wonder if anyone else ran into this problem and were forced to enlarge the hole. If the stock hole is big enough it's a 5 min fix but if I have to enlarge it that will take more time. Just curious what I need to plan for.
Old Sep 15, 2008 | 01:53 PM
vetteguy11's Avatar
vetteguy11
bump
