need QUICK answer on lowering
Old Sep 14, 2008 | 12:07 AM
vetfeva2's Avatar
vetfeva2
Default need QUICK answer on lowering
OK, i have a 2000 without that ride select option and i have lowered it on stock bolts. I am planning on buying another 2000 to add to the collection tomorrow. It has the ride selct option. Can i lower it without adversely affecting this option?
Old Sep 14, 2008 | 12:15 AM
mqqn's Avatar
mqqn
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In V Veteran
St. Jude Donor '03-'04-'05-'06-'07-'11
Hi vetfeva2 -
The problem that I ran into on a f45 equipped car was on the front - the solenoid (or whatever the bulging thing is) on the front shock interfered with the ride-height adjusters when you attempt to unscrew them -
I have read others post where they did not interfere.
Perhaps you can rotate the shock to put the bulge in the shock opposing to allow clearance for the ride-height adjuster as it is backed all the way out.
The function of the system would be not be impacted.
best regards -
mqqn
Old Sep 14, 2008 | 01:18 PM
FKING1's Avatar
FKING1
I lowered my 2000 F45 about 2" without a hitch. Only problem was shocks bottoming out on big bumps.
To need QUICK answer on lowering
