Temporary Tire Fix
Old Sep 14, 2008 | 12:34 PM
Rifeman's Avatar
Rifeman
Default Temporary Tire Fix
I got a flat on my passenger side front tire and the hole is in a tricky spot. I took the tire off and the hole is right on the "corner" of the tire, where the tread meets the sidewall. I tried using my plug kit (twice), to no avail. I ordered new tires, but they aren't coming in till Friday. I need something to keep the tire serviceable until then. I'm thinking about one of those products you inject through the valve, but I'm worried it might damage the wheel? HELP!!
-Chad
Old Sep 14, 2008 | 01:15 PM
mike348's Avatar
mike348
Why would the plug not work. Was the hole too big?
Old Sep 14, 2008 | 01:28 PM
RobertEarl's Avatar
RobertEarl
Find an auto parts store that sells Safety Seal tire repair kit. It is not cheap ( $35 ) but it will fix it. Around here, NAPA sells them.
Reb
Old Sep 14, 2008 | 01:33 PM
10U 99's Avatar
10U 99
St. Jude Donor '08-'09
being the puncture is where it's at, it will be iffy to find anything that will seal and hold.
good luck
Old Sep 14, 2008 | 02:00 PM
Mr.Bill's Avatar
Mr.Bill
From: Reno is so close to Hell you can see Sparks , State Of Confusion
St. Jude Donor '12-'13-'14
You can try to remove the tire and maybe it can be patched, If you are running TPMs the last thing you want to do is put tire goop in there.. Maybe you can find a cheap take off from a tire shop to get you by for the week.
Old Sep 14, 2008 | 03:14 PM
Rifeman's Avatar
Rifeman
Not sure what TPMs are. Also, the tire is already off the car, so I'm leaning toward the patch idea. Why don't I want tire goop in there?
Old Sep 14, 2008 | 03:17 PM
TNX ZORA's Avatar
TNX ZORA
Make sure you're using the rope type plug and not the rubber type. There's different sizes of them and you need to use a big enough one or even two together. I've never had a flat that a rope type plug wouldn't seal.
Old Sep 14, 2008 | 03:19 PM
DeeGee's Avatar
DeeGee
If it affects the sidewall or is close to the corner no shop will plug it particularly a high performance tire
If its an OEM run flat just drive it. The tire will run for ever. the only problem is that its only rated for 200 miles flat and then you can't repair it. If you plan to replace it no problem. It won't get close to damaging the rim. Just keep the speed down to a sensible level, say below 50. If you've ever driven one of these flat the sidewall is so hard you barely know its flat. It'll get you around safely until the new one arrives.
Old Sep 14, 2008 | 03:21 PM
Mr.Bill's Avatar
Mr.Bill
Tire Pressure monitors (sensors). The goop will ruin them.
Old Sep 14, 2008 | 03:31 PM
rws.1's Avatar
rws.1
internally patch it.
Old Sep 14, 2008 | 05:26 PM
c5streak's Avatar
c5streak
The last two tires I plugged that had a hole on the "corner" of the tread,(one on a trailer & one on my truck), both disintegrated afterwards at hwy speeds. I would opt for the patch idea until your new tires come in.
Old Sep 14, 2008 | 05:57 PM
hotwheels57's Avatar
hotwheels57
Do to the location of the puncture, you might have to try the temporary patch yourself. Most tire shops will not do it for fear of liability...
Old Sep 14, 2008 | 06:47 PM
N4cer's Avatar
N4cer
What about those mushroom plugs that work from the inside out?
Old Sep 14, 2008 | 07:19 PM
c5BlackBeauty's Avatar
c5BlackBeauty
Lifetime Member
St. Jude Donor '05, '12-'13, '15-'16, '21
good luck
Good Luck
Old Sep 14, 2008 | 09:25 PM
bucwheat's Avatar
bucwheat
You can't fix A tire with damage that close to the side wall,It won't work.
Old Sep 14, 2008 | 11:05 PM
Rifeman's Avatar
Rifeman
The goop and the internal patch won't work? And if so, why not?
Old Sep 14, 2008 | 11:44 PM
jrose7004's Avatar
jrose7004
I would agree.
To Temporary Tire Fix
Old Sep 15, 2008 | 05:30 AM
Injecting a can of something like Fix-A-Flat into the valve stem could very well ruin your tire pressure sensor, which is attached to the valve stem. Based on your description of where the puncture is, it may be hard to get a patch to work properly and safely. It might be best to just not drive the car until the new tire comes in.
Old Sep 15, 2008 | 12:04 PM
jovette's Avatar
jovette
Wonder if you could find a radial tire tube that would work for a short period of time, and wth driving conservatively? Just remove the TPS, and insert the tube valve through the valve stem hole in the wheel?
Old Sep 16, 2008 | 12:12 AM
Rifeman's Avatar
Rifeman
Thanks for all the feedback. I'm just gonna keep the car on jacks until the new tire comes in.
