True hp rating
Old Sep 14, 2008 | 09:39 PM
SCRMNC5's Avatar
SCRMNC5
Default True hp rating
from the fatory what is the % decrease from cramk to wheels?
stock would be 350, Im assuming around 290 or 300 at the wheels. can anyone help?
Old Sep 14, 2008 | 09:56 PM
Silverbullet00's Avatar
Silverbullet00
From: Norman Oklahoma - The Only State in the Union with no Blue Counties!
The rule of thumb is 15% loss from the flywheel to the wheels but all cars are somewhat variable. My car, when it was stock was rated at 345 at the FW, a mustang or weight loaded dyno revealed 293 HP at the wheels
Old Sep 15, 2008 | 06:15 AM
bigbadfast's Avatar
bigbadfast
I was 307 bone stock
Old Sep 15, 2008 | 07:52 AM
08 ATOMIC-Z's Avatar
08 ATOMIC-Z
Mine was 312RWHP stock.
Old Sep 15, 2008 | 10:04 AM
98vertvette's Avatar
98vertvette
Stock for me was 293,
Old Sep 15, 2008 | 10:23 AM
itzza427's Avatar
itzza427
It can also vary with transmission,,an auto will have less RWHP than a MN6. If you have a stock (untuned ECM) repeated runs will result in small gains (for a while) as it adjusts air/fuel for wide open throttle (WOT) running.Mine was used in a dyno display at the mid west Nationals,where they did 3 pulls the first time and every hour there after did 2 more pulls for a total of 13 pulls.first pull read out was323.51hp/324.76tq the last read out 338.9/345.91. Early on the top end A/F was rich and each pull showed a very small A/F adjustment and power torque increase. Basically this is what the tuners do,,they know what the upper end ratios should be and "tell" the computer to run there.
Old Sep 15, 2008 | 10:28 AM
It's about 15% loss with a manual tranny, 18% or so for an auto.
Old Sep 15, 2008 | 10:41 AM
SCRMNC5's Avatar
SCRMNC5
Thanks for all the input guys, appreciate it.
To True hp rating
