Dam turn signals
Old Sep 15, 2008 | 01:41 PM
Enemy's Avatar
Enemy
Default Dam turn signals
So I'm having an issue with my turn signals, once in a while when I go to signal nothing happens, (left or right), I hit the emergency lights and that triggers my signals to start working again, I have checked all connections and they are all fine and could not find any burned out bulbs. Anyone have/had this issue?
Any help os much appreciated
Old Sep 15, 2008 | 01:44 PM
FrankTank's Avatar
FrankTank
CI 7-8-9-11 Veteran
St. Jude Donor '06-'10, '13
Did you check the fuses, relay or flasher? I assume yes?
Old Sep 15, 2008 | 01:50 PM
poolboy's Avatar
poolboy
You said that after hitting the emergency flashers, they (the turn signals) start working again, so have you changed the emergency flasher switch? They are known to go bad and cause turn signal failures....
Old Sep 15, 2008 | 02:34 PM
Enemy's Avatar
Enemy
I have checked, fuses, flashers, like I said it's not always but id happens from time to time, I can go a few months without any issues and all of a sudden it doesn't work
Old Sep 15, 2008 | 02:37 PM
c5streak's Avatar
c5streak
Bad hazard switch. Here's how to replace it if you want to tackle it yourself, part# 10359036.
http://myweb.cableone.net/kd5fx/HSwitch/HS029.jpg
Old Sep 15, 2008 | 02:38 PM
DeeGee's Avatar
DeeGee
You need to change the hazard warning switch
Old Sep 15, 2008 | 03:52 PM
Wop1's Avatar
Wop1
Common problem with a simple low cost solution, search the Froum for a post named Turn Signal Magic and you'll learn how to solve this.
Old Sep 15, 2008 | 04:37 PM
dh305's Avatar
dh305
Same problem here. Just replaced Hazard switch and problem solved. Common Cc5 problem along with column lock bypass.
Old Sep 15, 2008 | 04:43 PM
rws.1's Avatar
rws.1
That is a link to the simplified fix...
Some other have been using a flasher bypass, I don't know anything about it
Hams's Avatar
Hams
Cruise-In VII Veteran
You can also buy a bypass relay from Richard at Corvette Enhancement, takes about 20 min. to install. PS Great service from Richard......Hams
Old Sep 15, 2008 | 04:54 PM
Enemy's Avatar
Enemy
sweet, thanks for all your help guys, I really appreciate it
Old Sep 15, 2008 | 08:54 PM
RonJ's Avatar
RonJ
My turn signal behaves just like yours and I think this winter I'm going to install one of those by-pass kits. Sounds like the way to go.
Meanwhile, I had noticed that with the turn signal lever on but no signal, it would start to work as soon as I pushed the hazard switch button in just a little bit. What I did, and it's worked for 4000 miles this summer, I pushed the hazard switch in a little bit and then wedged it with a tooth-pick. Works like a good thing!!! It's not a permanent cure but it'll do the job until it can be repaired properly.
RonJ ...
To Dam turn signals
